Home > Puma (Tdci) > Output Shaft
Page 5 of 5 <12345
Caterham
Pickles wrote:
Would that not be from the rear axle flanges?
I've had the clunk between gears from new, I've had the input shaft replaced (when it failed!), but the clunk is still there,..A frame ball joint could be an issue too?
Pickles.
on the subject of rear flanges. I replaced both of mine with the new rear diff, g.box and t.box and circa 5k miles later the one rear flange was well shagged / worn Shocked and hence replaced again while replacing rear wheel bearings.
why would one wear THAT quickly?
Post #675679 4th Jan 2018 12:42pm
MK
lack of lubrication Puma 110" SW
Post #675825 4th Jan 2018 7:57pm
UtilityTruck
When replacing rear drive flanges make sure you use the latest one piece shafts. No outboard spline to wear 2014 Keswick Utility 2.2
Post #675882 4th Jan 2018 9:50pm
Page 5 of 5 <12345
