Home > Td5 > Td5 10p engine locked up HELLLLPPPPP |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
does it turn over with the auxiliary belt removed? 2002 90 Td5 Station Wagon
2nd Jan 2018 7:56pm |
When you turn the engine over in reverse is there any noise from the bell housing? Thinking it could be a fly wheel issue. They do disintegrate, it is not beyond the release of possibility that it would prevent the engine turning over.
2nd Jan 2018 8:16pm |
Jeevo2001 Member Since: 31 Dec 2016 Location: Birmingham Posts: 25 |
thanks
Cant hear anything from the bell housing, but il have a listen to it tomorrow. Iv not removed the auxillary belt that was going to be my next step before checking the oil pump. I wasnt sure if there was enough resitance to lock the engine up, but was going to give it a try |
2nd Jan 2018 8:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
I had a td5 come in with seized engine, turned out to be collapsed tensioner bearing. Aux belt off and it started straight away! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Jan 2018 6:56am |
Amazing that a collapsed tensioner pulley could resist the starter motor... Hope it is as simple as this to sort out
3rd Jan 2018 11:34am |
Il give it a go when I get home from work.
Yeah I’m amazed it could be I assumed it would have snapped the belt Hopefully it is a quick cheap fix so I can get it to wagtail on the weekend |
3rd Jan 2018 11:38am |
Cheers guys found the culprit
Idler bearing £7 fix 😄. |
3rd Jan 2018 4:31pm |
thats great news.
in the case i had come in the bearing seizing stopped the engine! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Jan 2018 6:41pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
Forum help at its best
3rd Jan 2018 6:48pm |
Great help from the forum
Woulda ended up pulling he engine out the way I was approaching it |
3rd Jan 2018 7:01pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
Were there any symptoms before hand? Squealing belt or squealing pulley sounds?
Mine has been making these noises for the last few weeks when the weather started getting colder....should i be worried? |
3rd Jan 2018 7:21pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Top fix 1951 80" S1 2.0
3rd Jan 2018 7:34pm |
No real symptoms
I had noticed a very slight noise but nothing, |
3rd Jan 2018 8:31pm |
Fan blooming tastic... Well done JST good call |
3rd Jan 2018 8:46pm |
