Home > Td5 > Td5 10p engine locked up HELLLLPPPPP
Jeevo2001
Hi everyone just wondering if anyone could shine any light on what could be the fault with my td5
Driving along I lost drive and the engine cut out. I tried to crank the engine over and it wouldn’t turn.
We towed it home and attempted to jump start it but it just was locking the wheels up. With the clutch in the gearbox runs freely
I assumed something had seized up in the engine
We can turn the engine in reverse by the crank pulley but as soon as we go the other way it locks up.
The timing chain is still intact, the valves are all moving freely, we have removed the starter motor, removed the glow plugs everything looks fine.
Next job is to check the oil pump
Any other suggestions?
Thanks
Post #675220 2nd Jan 2018 7:34pm
grafty99
does it turn over with the auxiliary belt removed? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675223 2nd Jan 2018 7:56pm
geobloke
When you turn the engine over in reverse is there any noise from the bell housing? Thinking it could be a fly wheel issue. They do disintegrate, it is not beyond the release of possibility that it would prevent the engine turning over.
Post #675233 2nd Jan 2018 8:16pm
Jeevo2001
thanks
Cant hear anything from the bell housing, but il have a listen to it tomorrow.
Iv not removed the auxillary belt that was going to be my next step before checking the oil pump. I wasnt sure if there was enough resitance to lock the engine up, but was going to give it a try
Post #675237 2nd Jan 2018 8:26pm
jst
I had a td5 come in with seized engine, turned out to be collapsed tensioner bearing. Aux belt off and it started straight away! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675312 3rd Jan 2018 6:56am
geobloke
Amazing that a collapsed tensioner pulley could resist the starter motor... Hope it is as simple as this to sort out Thumbs Up
Post #675355 3rd Jan 2018 11:34am
Jeevo2001
Il give it a go when I get home from work.
Yeah I’m amazed it could be I assumed it would have snapped the belt
Hopefully it is a quick cheap fix so I can get it to wagtail on the weekend
Post #675357 3rd Jan 2018 11:38am
Jeevo2001
Cheers guys found the culprit
Idler bearing
£7 fix 😄.
Post #675442 3rd Jan 2018 4:31pm
jst
thats great news.
in the case i had come in the bearing seizing stopped the engine! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675488 3rd Jan 2018 6:41pm
V8GPC
Forum help at its best Thumbs Up
Post #675491 3rd Jan 2018 6:48pm
Jeevo2001
Great help from the forum
Woulda ended up pulling he engine out the way I was approaching it
Post #675493 3rd Jan 2018 7:01pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Were there any symptoms before hand? Squealing belt or squealing pulley sounds?
Mine has been making these noises for the last few weeks when the weather started getting colder....should i be worried?
Post #675497 3rd Jan 2018 7:21pm
familymad
Top fix Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #675502 3rd Jan 2018 7:34pm
Jeevo2001
No real symptoms
I had noticed a very slight noise but nothing,
Post #675522 3rd Jan 2018 8:31pm
geobloke
Idler bearing
£7 fix 😄.
Fan blooming tastic... Thumbs Up Thumbs Up Well done JST good call Thumbs Up Thumbs Up
Post #675530 3rd Jan 2018 8:46pm
