Home > In Car Electronics > Dab SPlitter Cable info only
Djcla
In case anyone comes across this thread i can confirm that the connects2 DAB splitter cable so far seems to worked for me with the stock aerial on my TD5, so no need for a second aerial.
https://www.dynamicsounds.co.uk/connects2-...itter.html
Post #675433 3rd Jan 2018 4:16pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
I’m using this one, seems to work ok most of the time:
http://www.dabonwheels.co.uk/Kinetic_DAA-7...itter.html
Post #675450 3rd Jan 2018 5:10pm
Djcla
They are probably all pretty similar there is an automated one as well.
Post #675456 3rd Jan 2018 5:17pm
grafty99
I keep meaning to get one of these, I found that the signal was pretty poor with a windscreen mounted one 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675473 3rd Jan 2018 6:00pm
Djcla
I had to tap into the amp remote blue and white cable on my harness for the power just and fyi. I'm hoping I can split that and run an amp off the same cable at a later date as well but not suit it will work.
Post #675478 3rd Jan 2018 6:06pm
hank
I am planning on moving to DAB and want to retain the OE aerial, is this still performing well?
Post #707252 15th May 2018 8:24am
Djcla
Yeah it's fine, some times when I start up it says no signal for 30 seconds but then sorts itself out
Post #707260 15th May 2018 9:49am
hank
Thanks. Have ordered one... Just need a DAB head unit to suit now!
Post #707285 15th May 2018 11:43am
Djcla
I bought this one, along with JBL speakers and a small Kenwood sub
http://www.halfords.com/webapp/wcs/stores/...reId=10001
Post #707288 15th May 2018 11:53am
Stacey007
Maybe a silly question
I'm looking at a new radio with DAB+
Do I need a splitter to connect to my existing aerial and use a windscreen mounted DAB one?
Or will the window mount one do normal FM and DAB+
Thanks
For the head unit I'm looking at I was told this one...
http://www.halfords.com/technology/car-aud...bestseller
Post #708727 23rd May 2018 8:50am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I fitted that one on the alpine window and connected to the DAB aerial input on my headunit then the existing wingtop one connected to the analogue input on the headunit. Keith
Post #708728 23rd May 2018 9:00am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Stacey007 wrote:
.... Do I need a splitter to connect to my existing aerial and use a windscreen mounted DAB one?
Or will the window mount one do normal FM and DAB+ ...
The stick on window mounted aerial is designed for DAB use only. You would still need the existing OE aerial for FM.
The splitter allows the use of the original aerial for FM and DAB thereby eliminating the need for the stick-on aerial.
Works for me Thumbs Up
Post #708738 23rd May 2018 9:48am
Djcla
As above
Post #708810 23rd May 2018 6:25pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
dito ! Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #708840 23rd May 2018 8:52pm
RockfieldWines
Wales 2007 Defender 110 Puma 2.4 DCPU Baltic Blue
I took mine into halfords to have DAB radio CD etc fitted and after 2 hours they stated there was no location where they could get the aerial signal to work so they refunded me. Where do other people place thiers
Post #708904 24th May 2018 11:16am
