![]() | Home > Td5 > Break inertia switch circuit to disable Defender |
Spanner Member Since: 16 Nov 2017 Location: Pembrokshire Posts: 10 ![]() ![]() ![]() |
The thing I like about the inertia relay is that the engine will still turn over but not start. This I think makes it ideal if someone is trying to pinch the car from outside the house. If they've bypassed the alarm then the engine turning over but car not starting would act as an alert and hopefully they'd scarper once attention is drawn.
There's also a couple of idea's that have been PM'd to me that I won't mention here which should be enough to deter all but a pro. As has been said, if some scrote wants it enough then it's gone but at least we might be able to slow them down. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Hi Spanner,
I've PM'd you a potential immobiliser option ![]() There are numerous immobiliser options relating to the inertia and main relay circuit - the latter being in the main feed to the coil of the former. There's a very, very, easy opportunity to interrupt the 'ignition' (whilst still allowing the starter to turn) by inserting a cleverly concealed switch/device between the negative side of the coil of the main relay and pin 21 on the ECU - both co-located. Hopefully you are now spoiled for choice ![]() Cheers, Will |
Hi Will,
Got your pm, many thanks for the detailed information. It looks to me like it would possible to make a Defender so troublesome to start unless you know where the switches are that it won't be worth the trouble of pinching. I'm now thinking of the combination of switches and knobs it takes to start the truck in Mad Max Fury Road... Thanks again and happy New year. Cheers, Ken |
gliderbee Member Since: 05 Dec 2016 Location: Lubbeek Posts: 12 ![]() ![]() ![]() |
I would like to do this on my 2.2 Puma (2016) and I could use the info on the alternative way of switching. Can you pm it ? Kind Regards, Stefan. |
Hi Stefan,
Will should really respond to this as it's his diagram. I don't know enough about Defender electrics to know if the same idea would work on a Puma (I've seen mention that some of them don't have inertia switches) but hopefully someone will know. Cheers, Ken |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1088 ![]() ![]() ![]() |
I'd be interested in other solutions for the Puma, too, so I've opened a thread there http://www.defender2.net/forum/topic58823.html
Or we could just exchange PMs ![]() cheers Frank |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
No offence to any of the posters here, but is it really wise to give out this type of information to members with so little posts? If I had a good and secret way of disabling my motor I really would only be sharing it with people who have a good track record of posting and contributing on here. As said, no offence intended to any of the posters.
I can understand where you're coming from but it does leave new owners stuck between a bit of a rock and a hard place. Last time I owned a Defender was about 15 years ago and I didn't give theft a second thought. When I managed to scrimp enough to buy another one it didn't take long to find dozens of posts about how easy they are to pinch, how many are pinched and how they are now a rolling goldmine for thieves.
The question almost becomes whether to keep a vehicle that you're going to be constantly worrying about or sell it and buy a Volvo instead! I'm not sure there's anything here that's new (the true guidance has come from PM's) and I asked the original question when I came across a post, I think on an Australian forum, asking pretty much the same question. My own lack of posting history is due (touch wood) to not having any real problems yet and having a vehicle old enough that the last decades worth of posts here and elsewhere cover pretty much everything I can imagine wanting to know. That and not knowing enough to answer anyone else's questions yet. |
Yes I agree with the points made - I can appreciate and understand the various perspectives.
Best to keep this information flowing via PM. Just trying to help ![]() |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Some trackers have a remote controlled relay which can be connected to a circuit to effectively immobilise the vehicle should the worst happen..
Would this inertia switch be a reasonable candidate for that? Imagine if you noticed your defender being driven unlawfully and you wanted to immobilise it (at a point where it may be safe to do so). Ie, if the line was broken, would it stop the engine from running or only stop it from starting next time? My 90 Project : http://www.defender2.net/forum/topic52774.html |
Stop it running on a TD5 - not sure about Puma
thanks, I'll see if I can locate the offending item and see how it responds on a puma My 90 Project : http://www.defender2.net/forum/topic52774.html
Please share your results. I will try myself once I get an OBD device to clear the error that will/might be generated. Still under warranty, so a bit relucant to fiddle with cruical parts :-/ And I think the whole point of the inertia switch is to stop a running engine, in case of an accident ![]() |
I’ll have a look and see what I can find under the bonnet. I have a reset tool so it should be ok! My 90 Project : http://www.defender2.net/forum/topic52774.html
