Home > Maintenance & Modifications > Warn premium shackles
Spotted these online earlier.
Does anyone have any and any pics? What do you think of them?
They aren't cheap though, at the moment I have have 3.5T bow shackles on FF swivels.
I'm tempted one day, but what I have now is perfectly fine so just thinking about the look of them really and whether anyone else has them.
I think there is matching snatch blocks and winch hooks also.
If you haven't seen them before, they might be worth a look. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #675084 1st Jan 2018 11:57pm
Got pics:
Post #675091 2nd Jan 2018 1:19am
mse
Someone was selling them on here a while ago, I saw then in the states...I would buy them for the cool factor but they are warn expensive Exclamation Mike
Post #675092 2nd Jan 2018 1:42am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I'm sure being Warn that they are good solid products, however, I'm going to get controversial here.
I think they look like Tonka Toy versions. Whistle 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #675099 2nd Jan 2018 9:38am
jst
I don't see the point in paying extra for looks on a shackle or hook. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675100 2nd Jan 2018 9:43am
agentmulder
Kuwait
Thumbs Up Solved the bowel problem, working on the consonants...
Post #675107 2nd Jan 2018 10:57am
zsd-puma
Well the hook may be as it's visible on the car most of the time, but shackles no. Laughing
Post #675110 2nd Jan 2018 11:00am
leeds
Whilst that shackle and hook may be more expensive then a lot of similar items in the market place , even if they look like 'Tonka Toys' they are from a reputable manufacturer you can be reasonably assured that they are fit for purpose and meet or exceed any legal requirements.
What I would be more concerned about is the so called 'equipment' at the other end of the market place.
So called straps which are rated by the weight of the vehicle it can tow on a flat level road. Gives no indication of the strap UTS or MBS.
Recovery hooks without a WLL or safety catch
A 5 tonne strap with a lower UTS .then the UTS on a 2 tonne WLL strap. The 5 tonne strap has a safety factor of 1.2 or UTS of 6 tonne whereas the 2 tonne strap has a safety factor of 7 or a UTS?MBL of 14 tonnes.
Items declared as E marked and road legal without correct approval markings.
Buy cheap, risk your life, and pay 2 or 3 times over.
Brendan
Post #675118 2nd Jan 2018 12:02pm
jst
there are plenty of other SWl and WLL shackles hooks out there no where near these prices from reputable suppliers. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675123 2nd Jan 2018 12:36pm
zsd-puma
Brendan
I don't think the original post was about buying cheapo unbranded hooks. It was simply about Warn's 'premium' hooks and shackles compared to their standard ones. I mean the hook Warn supply as standard with their winches will be good quality and fully safety rated. These standard hooks appear expensive compared to budget ones for that reason, but their premium ones are even more expensive for little more benefit than asthetics.
Post #675130 2nd Jan 2018 1:05pm
They are simply 'premium' just that, I haven't looked into specs specifically but being from Warn you can trust they are fit for purpose.
The costs is pretty much a brand price tag, and aesthetic pleasing.
Many often PC or paint them too, again for astetic reasons because they are highly visible.
What's the point you may ask?
Well... if use them, of course they will damage the finish but who cares?
They can be refinished, easy as that.
As they are designed some of them fit for use for say Ford F-250's (as a example) that are massively heavy they certainly can take Defender weights no problem.
A bigger concern would be to me, is not specs or looks of them or any of that. But the that fact they are removable in minutes and are not cheap at all.
A bit like leaving a few Β£50 notes on your front ready to to steal, and if you have to keep them off for that very reason and only use them when needed well that is besides the point.
Personally, I really like them but the price tags put me off somewhat. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #675134 2nd Jan 2018 1:20pm
Another couple of photos I have found:
Post #675137 2nd Jan 2018 1:41pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Thumbs Up Thumbs Up
Post #675179 2nd Jan 2018 5:31pm
Devon-Rover
Metal shackles are a bit 2010. The Dyneema soft shackle is where it's at, There is a few areas of high wear e.g. strop to pulley block where there is a sharp edge but IMHO for weight saving and higher strength then the soft shackle is best.
Post #675209 2nd Jan 2018 7:47pm
jst
soft shackles can also fit into car recovery points which i have found to be an issue with some shackles. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675234 2nd Jan 2018 9:22pm
