![]() | Home > Puma (Tdci) > Break circuit to disable Puma |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
Hi,
the TD5 guys seem to have numerous ideas on how to install a hidden kill switch, i.e. which wires to break http://www.defender2.net/forum/topic58741.html Has anyone done any of this on a Puma (2012+ in particular)? I assume some TD5 solutions might generate ECU error codes or even limp-home mode on a Puma?? Also the fuel pumps are different and I'm not sure the TDCi likes the fuel being cut off? PMs appreciated if you don't like to share it here. cheers, Frank |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
The 2.2 puma has the same inertia switch as the td5 on the bulkhead so the same applies as to the td5. Disconnect it and it won't run
![]() The only code you'll get in a puma is crash switch activated code if you try to start it with the switch disconnected ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
No limp mode or engine lights though
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Anything for the 2.4 pumas? Solved the bowel problem, working on the consonants...
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Pm’d You Frank 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
The problem with the y connector method is easily overcome if the scroats are looking for it.. And the use of the inertia switch is becoming more widely known....i would suggest hiding the place you cut into the switch the best you can |
