Home > Puma (Tdci) > Break circuit to disable Puma
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi,
the TD5 guys seem to have numerous ideas on how to install a hidden kill switch, i.e. which wires to break
http://www.defender2.net/forum/topic58741.html
Has anyone done any of this on a Puma (2012+ in particular)?
I assume some TD5 solutions might generate ECU error codes or even limp-home mode on a Puma?? Also the fuel pumps are different and I'm not sure the TDCi likes the fuel being cut off?
PMs appreciated if you don't like to share it here.
cheers,
Frank
Post #675104 2nd Jan 2018 9:48am
grafty99
The 2.2 puma has the same inertia switch as the td5 on the bulkhead so the same applies as to the td5. Disconnect it and it won't run Thumbs Up
The only code you'll get in a puma is crash switch activated code if you try to start it with the switch disconnected Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675108 2nd Jan 2018 9:58am
grafty99
No limp mode or engine lights though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675109 2nd Jan 2018 10:00am
macfrank
thanks, that sounds promising Thumbs Up
Have you actually done it? I guess it's possible to get a male and female plug in order to make a non-invasive modification? I'd rather not cut the cables there, as the intertia switch is so close to the MCU and the cables so short.
I'd also be intersted in other wires to break, maybe even without the need to route new cables through the bulkhead?
Post #675236 2nd Jan 2018 8:24pm
agentmulder
Kuwait
Anything for the 2.4 pumas? Solved the bowel problem, working on the consonants...
Post #690186 2nd Mar 2018 10:21am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Pm’d You Frank 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #690197 2nd Mar 2018 11:06am
nitram17
The problem with the y connector method is easily overcome if the scroats are looking for it.. And the use of the inertia switch is becoming more widely known....i would suggest hiding the place you cut into the switch the best you can
Post #690226 2nd Mar 2018 1:24pm
