Home > Technical > Were do the wires go? |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
Hi.
I'm fitting rear speakers.There are a pair of wires with speaker plugs but they are not on the radio end plug.Were do these lead too?I'm in a flat spin as I'm leaving for a trip in 48hrs and would like music in the back. Puma 110 SW 90 V8 SOFT TOP |
13th Apr 2011 5:07pm |
Schulli Member Since: 29 Mar 2011 Location: Bush Posts: 6 |
Blue/Black ? Accessory socket, always 12v. If i remember correctly 30A.
13th Apr 2011 7:30pm |
I found were they lead to.They lead to plug next to the heater box in the engine bay.All what is needed is to connect wires from this plug to the radio through the firewall.Would have cost LR peanuts to connect to radio plug from the start. Puma 110 SW
90 V8 SOFT TOP |
15th Apr 2011 2:29am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
That's Ford's penny-pinching influence You have the female connector on the Chassis Harness side of the junction (C0379), I don't know if you have a blanked-off male connector on the Main Harness side (C1762 for 110, C0393 for 90), or a cover over the open side of the female chassis connector. The connectors are 4-way Sumitomo HW Sealed Series, if you need the mating connector half, they can be bought from Eastern Beaver in Japan - As a - Male/Female set with terminals and seals - 4P090WP-HW Male connector with terminals and seals - 4P090WP-HW-Male Female connector with terminals and seals - 4P090WP-HW-Female http://www.easternbeaver.com/Main/Elec__Pr.../smhw.html If you just need compatible terminals and seals, they can also be bought from Eastern Beaver, or from Polevolt in the UK - http://www.polevolt.co.uk/acatalog/Sumitomo_Treminals.html [sic] Polevolt's Part Numbers (same as Sumitomo's) - Male terminal - 1500-0105 Female terminal - 1500-0110 Wire Seal (fits both male and female) - 7165-0118 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
15th Apr 2011 8:10pm |
