Home > Technical > Were do the wires go?
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Hi.
I'm fitting rear speakers.There are a pair of wires with speaker plugs but they are not on the radio end plug.Were do these lead too?I'm in a flat spin as I'm leaving for a trip in 48hrs and would like music in the back. Puma 110 SW
90 V8 SOFT TOP
Post #67189 13th Apr 2011 5:07pm
Schulli
Germany 2011 Defender 110 Puma 2.4 SW Santorini Black
Blue/Black ? Accessory socket, always 12v. If i remember correctly 30A.
Post #67208 13th Apr 2011 7:30pm
LESVOSD110
I found were they lead to.They lead to plug next to the heater box in the engine bay.All what is needed is to connect wires from this plug to the radio through the firewall.Would have cost LR peanuts to connect to radio plug from the start. Puma 110 SW
90 V8 SOFT TOP
Post #67389 15th Apr 2011 2:29am
Possibly.... but "peanuts" x many thousands of produced LR's equals a lot of nuts Laughing
Post #67401 15th Apr 2011 6:43am
PaulMc
That's Ford's penny-pinching influence Sad
You have the female connector on the Chassis Harness side of the junction (C0379), I don't know if you have a blanked-off male connector on the Main Harness side (C1762 for 110, C0393 for 90), or a cover over the open side of the female chassis connector.
The connectors are 4-way Sumitomo HW Sealed Series, if you need the mating connector half, they can be bought from Eastern Beaver in Japan -
As a -
Male/Female set with terminals and seals - 4P090WP-HW
Male connector with terminals and seals - 4P090WP-HW-Male
Female connector with terminals and seals - 4P090WP-HW-Female
http://www.easternbeaver.com/Main/Elec__Pr.../smhw.html
If you just need compatible terminals and seals, they can also be bought from Eastern Beaver, or from Polevolt in the UK -
http://www.polevolt.co.uk/acatalog/Sumitomo_Treminals.html [sic]
Polevolt's Part Numbers (same as Sumitomo's) -
Male terminal - 1500-0105
Female terminal - 1500-0110
Wire Seal (fits both male and female) - 7165-0118
. Paul.
Post #67493 15th Apr 2011 8:10pm
