Home > Td5 > DEFENDER 90 TD5 NO ENGINE ACCELERATION AFTER ENGINE WASH
HUGHZEB
2003 Defender 90 Td5 HT Alpine White
Hi, I took my 2003 Defender 90 TD5 for an Engine wash (which was done with the engine running). after the wash, i backed it up ready to pull off and the orange engine light came on and it failed to accelerate. Engine kept running. Switched off the engine and started it again, it revs a bit and then does the same thing with the light coming on and fails to accelerate.
Has anyone had a similar problem. Please help!
Post #673717 28th Dec 2017 2:22am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Have never had this problem but then I never wash my engine !!! Did you pressure wash it ? As a pressure washer is quite capable of pushing water past the seals on sensor connections on the engine I would be inclined to disconnect the connections to the maf sensor, the map sensor, crank position sensor and any other connections you can see and make sure they are dry if wet blow out with compressed air if available if not use paper towel to soak up excess moisture then spray with WD40 or similar. Also make sure your air filter and housing are dry, whilst in there check the ambient air temperature sensor that lives in there and check it’s connections for moisture ingress.
Hope this helps. 2005 Td5 90 XS
Steve
Post #673773 28th Dec 2017 1:00pm
lightning
I’m not sure l would jet wash an engine at all, let alone do it while it is running.
Post #673962 28th Dec 2017 11:07pm
bankz5152
I jetwash mine on a lower setting, sometimes its caked in muck and needs a clean!
Not sure whats happened, could have killed the crank sensor. Ideally you need to plug in to some diagnostics
Post #673966 28th Dec 2017 11:12pm
rallysteve
Remove airfilter and make sure it isnt wet.
Doubt crank sensor is the issue as it would not run at all. 02' 110 TD5 Double Cab Rebuild Thread
Post #673980 28th Dec 2017 11:39pm
bankz5152
Not totally true. I had an intermitant starting/running fault (would cut out randomly) after some deep wading. Changed the sensor perfect again.
110 had a slow starting issue which was also down to the crank sensor.
Post #674053 29th Dec 2017 11:57am
Willbof
Wales 2012 Defender 110 Puma 2.2 XS CSW Zambezi Silver
Definately check the air filter, got a bit deep wading once and had similar symptoms. Filter had gotten damp and a chunk fell off which ended up in the maf sensor!
Post #678269 13th Jan 2018 11:33pm
roel
Sounds like a throttle pedal position sensor problem to me. Roel
2003 90 Td5 (2009-now)
Post #678352 14th Jan 2018 1:48pm
annette
Costa Rica
disconnect all cables on the engine, dry, spray contact cleaner and reconnect.
Use the opportunity to relocate all those that were full of . Fixing Land Rovers in rural Guanacaste
Post #679289 17th Jan 2018 5:20pm
atakanmerdin
Kenya
Echoing this sentiment as well. CPS if faulty can start engine but cuts out randomly! Changing this also fixed my intermittent and dead throttle issue.
Post #684704 7th Feb 2018 6:32am
