Home > Puma (Tdci) > Engine coolant life
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Engine coolant life
I notice there is a label under the bonnet of the 2.4 saying do not drain the coolant.
Mine however has changed from a nice orange colour to a brown rust colour, so thinking of changing it.
The car is a 2011, so I guess the coolant must be near the end of its life from a anti corrosives additive point of view.
Post #673013 24th Dec 2017 11:18am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
I think the OAT coolant change is every 10 years but for Β£30 i would do it now.
Post #673039 24th Dec 2017 12:15pm
Jonno
I will, it's seen better days. Quite a sudden change from clear orange to murky rust....
Post #673049 24th Dec 2017 1:01pm
dorsetsmith
Re: Engine coolant life
https://www.defender2.net/gallery/albums/u...2.4D~0.pdf
Post #673058 24th Dec 2017 1:33pm
For the cost of it and as it needs doing so infrequently I'd use pre mixed coolant. (I use Inugel Optimal.)
I found when I done mine, it was running generally around a degree cooler afterwards.
Maybe combined with new Waterpump though also.
But personally, concentrate is not something I'd choose. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #673065 24th Dec 2017 2:20pm
zsd-puma
As above it's 10 years, but does no harm to do it sooner.
I'd definitely use ready mixed, if you're in a hard water area then pre-mixed should already be mixed with distilled water. The left over bit makes topping up much easier, the price is more or less the same from Euro car parts whether you get concentrate or ready to use.
Post #673070 24th Dec 2017 2:54pm
Opie is hard to beat, because we gave our 'DEF2' discount code to use as well. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #673082 24th Dec 2017 5:00pm
ericvv
Don't like the "sudden change" bit of your phrase. Suggest you change the coolant but monitor if and how the colour will eventually change again. It should not really change at all.
As to the general question about changing the coolant fluid mix, my 9 year young truck has about 88.000 KM now. The coolant has already been replaced twice in that period, each time on occasion of a waterpump replacement. Last time for the PEL500110.
I don't like the idea of JLR maintenance recommendations to replace the coolant only every 10 years or 200.000 KM. Sounds awfully long to me for the anticorrosion and other additives to still properly do their job. Even without waterpump replacement, I will have it drained and changed every 3/4 years or 25.000 KM.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #673110 24th Dec 2017 6:15pm
