Home > Tdi > Fuel: white smoke |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 504 |
Have you tried isolating each injector to see if it's a particular injector causing the problem? Or possibly water in your diesel? Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
24th Dec 2017 10:40am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I recently put a new fuel tank in and I've put a couple of tanks of fuel through it so im pretty sure it's not water in the fuel.
How would I isolate which injector is causing issues if it is them? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
24th Dec 2017 10:43am |
With the engine running, loosen the union on each injector, one-by-one and see if the smoke stops Matt.
24th Dec 2017 10:45am |
It's worth a shot, will a knackered injector cause mpg to drop? 1993 200 Tdi 90 CSW
24th Dec 2017 11:09am |
Well white smoke, if it's not water in the system, is usually very excessive overfuelling. Black smoke is overfuelling but the fuel still partially ignites whereas white usually indicated a significant excess. So yes, I would guess that if the white smoke is unburnt fuel from a faulty injector you would have a lot lower mpg?
All kind of guesswork but it makes sense in my mind Hope this helps! Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
24th Dec 2017 11:13am |
Yeah I agree, so theoretically when the union is loosened it should be obvious I hope!
Will let you know how I get on, thanks for the advice 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
24th Dec 2017 11:55am |
Hi Kit. White smoke can also be oil bypassing the bearing seal on the exhaust side of the turbo. Can cause quite the amount of white smoke with not a great drop in oil level. Would be worth checking the play in your turbos impeller, especially axial in/out play. Should be negligible.
24th Dec 2017 1:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8094 |
when is it worse? startup/underload/over run?
when was timing belt last done Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Dec 2017 5:41pm |
Timing belt was done recently (2 months ago) do you think it was setup wrong?
It's at worst on start up and incrementally gets better until the engine has fully warmed up I'll check the turbo too 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
24th Dec 2017 8:28pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Yeh it will be one injector, do the slacken illiminator test, to find it, , i"v had this , lots of white smoke on start up. clears when engine is hot,, usually the idle is erratic when cold,, theres full sets of recon injectors on ebay, £190,
24th Dec 2017 10:51pm |
Sure check it, but it now sounds like this is not the cause. Sounds like a timing or fuel pump issue. |
24th Dec 2017 11:05pm |
Any recommended sellers? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
25th Dec 2017 12:25am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
kit, id change the glow plugs in case that's causing problems, sometimes one can go down causing some white smoke at start up. My Dturbo had this problem. before you go about injectors as mentioned, and also change where you fill up in case its a bad batch of diesel Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
25th Dec 2017 2:01am |
I would check timing belt first for piece of mind Cheers
25th Dec 2017 7:59am |
