Home > Td5 > New calipers
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
New calipers
Hello everyone!
While replacing both of my front wheel bearings yesterday I took the opportunity to have a good look at my front brakes as the car has pulled to one side a little under breaking a couple of times recently. I have pistons well and truly seized on both calipers (others pulled the dust covers with them when I clamped the free pistons and pressed the brake pedal) so it's definitely new calipers time. I was going to replace the discs as well so I may as well do a full overhaul of the brakes.
Having searched it seems that I can swap my standard solid disks for vented if I change the calipers to vented as well. The price difference seems very small so is there any reason not to go vented? I was looking at getting AP Lockheed calipers as a like for like swap?
Any issue to doing this? The should be a direct swap right?
Post #673018 24th Dec 2017 11:27am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Yes a good mod and definitely worth doing whilst you are changing the calipers anyway as it is low cost.
Standard brakes are ok but the vented discs dissipate the heat quicker so are less likely to overheat. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #673027 24th Dec 2017 11:45am
Appleby
Great news!
I'll get all the bits ordered. I needed to flush and replace the brake fluid anyway. While I've got it all apart I may treat it to some braided brake lines to top it all off.
Post #673034 24th Dec 2017 12:08pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Check the insurance angle they look for any excuse not to pay out.
Post #673037 24th Dec 2017 12:12pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Worth checking companies like tmd/irb who do big brake upgrades to see if they have any take off which would be discs and calipers td5 and Puma are the same and might be a cheaper way to do it 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #673066 24th Dec 2017 2:27pm
Appleby
Well everything arrived and I started fitting today in the cold!
However I now have the issue the brake pipes are well seized into the old calipers. I'm going to wreck them getting the out so it's time for new ones. While I do is it worth going for braided brake lines as well?
Goodrich, Hel or someone else? (Also can someone link me to a kit for fronts and rears on a td5 non ABS?)
Post #680247 20th Jan 2018 8:14pm
bankz5152
Well worth braided lines, got for +2s for a little extra length.
Got goodridge on mine, very good. You need the 3 pipe kit.
Post #680250 20th Jan 2018 8:27pm
