Home > Technical > Grease for propshaft UJs (original) |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
I just use normal lithium grease in mine, same as I'd use in the wheel bearings.
The grease you pumped out was just old and knackered |
24th Dec 2017 9:49am |
Hello UT. You are right it is a heavy dark grease. I use a lithium based Morris K48 Moly grease for my UJs and wheel bearings. Works a treat.
24th Dec 2017 9:50am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
That K48 moly grease looks like the stuff to use, I'll get some on order! 2014 Keswick Utility 2.2
24th Dec 2017 10:05am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
UJ uses lithium based grease. Sliding joints use Moly grease. Both NGLI2. Puma 110" SW
24th Dec 2017 10:54am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
How often do you grease uour props and wheelbearings?and do you need a special grease nipple?s i havent parden the language greased a nipple for many years can anyone reccommend a decent all round grease gun? Click image to enlarge Just a photo for festive cheer and to remind me of youthfil times before sealed bearings and when i was a dab hand with a grease gun..that was so last century! Youf is wasted on the young |
24th Dec 2017 10:57am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 916 |
Click image to enlarge I do the props every 4 or so months depending on conditions. If I have been doing offroad work then after cleaning I'll do them to put fresh grease in to keep things happy. It's easier than having to do a UJ swap. I have a swiss Wanner grease gun and it works well using comma high performance bearing grease. |
24th Dec 2017 11:05am |
The K48 moly from Morris is lithium based? NGLI2 refers to the 'consistency' only doesn't it? 2014 Keswick Utility 2.2 |
24th Dec 2017 11:09am |
NGLI refers to consistency. I do not use moly on UJs or bearings. Some people do. Puma 110" SW
24th Dec 2017 11:17am |
So what's wrong with moly grease? The page for the Morris lubricant makes it sound suitable, data sheet here- https://www.morrislubricants.co.uk/fileupl...559330.pdf
So any idea what is put in the joints at the factory? 2014 Keswick Utility 2.2 |
24th Dec 2017 11:50am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
As noted above, lithium based is best for rolling surfaces (UJs and bearings) and molybdenum based grease best for sliding surfaces (splines etc). That being said in normal applications (propshafts etc) either will be quite suitable, but I would not use moly for wheel bearings.
You don't need a special connector to grease the propshafts if you jack up one wheel so you can spin the prop, however the only correct way to grease the UJs thoroughly, which is seldom done now, is to unbolt one or both flanges so that you can fully articulate the joint. |
24th Dec 2017 12:10pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
I've used jcb blue grease on propshafts for years with no issues
24th Dec 2017 8:25pm |
