![]() | Home > Technical > Removal of upper and lower steering column shrouds |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Just take the steering wheel off. It's only a single nut. Just make sure your wheels are straight ahead and mark the wheel and column so it goes back in the same place.
The job is so much easier with the wheel out of the way and it's mad to try and work around it when it's so easy to remove. If we were talking about a Range Rover with an airbag and various steering wheel controls then it might be different. But it's pull the centre pad off, loosen the nut and yank/wobble the wheel loose then take the nut off and remove the wheel. Job done. |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
I'll second taking the wheel off. Dead easy to do.
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Right, got the wheel off, shrouds off, switched on all works!!! Only thing I can think is I disturbed something when I had the dash off to do my wipers, but that was several months and several thousand miles ago so.....?
Anyway, waggled all the wires round the switches, checked connectors, alls well so carefully reassembled and they still work so another Defender mystery! Thanks for your input guys and have a Merry Xmas and New Year ![]() Downside - can now take SWMBO to Tesco for “last minute” shopping ![]() Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 81 ![]() ![]() ![]() |
This is normally the switch playing up.
It takes all the current for the lights so if the contacts are poor it can overheat. If it plays up again have a look at the contacts in the back of the switch. The plastic starts to melt and the contacts sink in or get insulated by the plastic. The long term fix is a boomslang loom that takes the current draw from the battery and only uses the switch to activate relays. The dim dip relay can also cause issues and is best bypassed if still fitted. Hope your lights stay on although Tesco’s on Christmas eve doesn’t sound like fun! Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
Hi Baz,
Looks like I spoke too soon! Set off for Tescos dipped beam on. Did the Xmas scrummage, got in the car, no dipped headlights! My son had a similar problem on his 300 tdi 90 his headlights would only work if he held back the dim/dip stalk in flash position, turned out to be the master switch. But what I don’t understand is why main works and not dip, surely the master light switch sends headlight 12v to the dip/main beam switch which then sends it to either the dip or main filament? Externally my switches look fine no sign of melting or scorching. Looks like another strip down ![]() Chris 2010 Defender 110 Station Wagon, Santorini Black. |
I had this happen to me a while back. Turned out to be a burnt out relay.
I understand that, as standard, the only relay, unless you have dim dip (I don’t), is the power on relay which energises the headlamp supply when the “ignition” is turned on. This is ok in my case as I’m still getting power to the main beam. Pretty sure the problem is either the master lighting switch or the dip/main stalk. I’m going to replace the main switch first, then if this doesn’t sort the problem the dip/main stalk. And, shortly after that fit a Boomslang loom.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17690 ![]() ![]() ![]() |
Dip/main stalk switch.
Yep, think you might be right, I’m going down the “replace the cheapest part first” route then it should all be in good condition for the Boomslang next month. 2010 Defender 110 Station Wagon, Santorini Black.
