![]() | Home > Wheels & Tyres > New boots and wheels |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 722 ![]() ![]() ![]() |
Very nice. Just wind the lock stops out a bit to fix the rub.
![]() My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
Hmm yes one has snapped off
12mm x 50mm 8.8 bolt and haft nut
![]() STEERING ADJUSTMENT STEERING LOCK STOPS Service repair no - 57.65.03 Check 1. Measure clearance between tyre wall and radius arm at full lock. This must be not less than 20 mm. Adjust 2. Loosen stop bolt locknut. 3. Turn stop bolt as required. 4. Tighten locknut. 5. Check clearance between tyre wall and radius arm on each lock. NOTE: Alternatively lock stop adjustment may be carried out using following procedure. Check 1. Measure stop bolt protrusion �A�. Refer to table for correct setting. Adjust 2. Loosen stop bolt locknut. 3. Turn stop bolt as required. 4. Tighten locknut. 5. Check wheel position at full lock. LOCK STOP SETTINGS Tyre & wheel size - alloys Make Size Setting BF Goodrich Mud Terrain 265 59,7 mm Goodyear GT+4 235 55,7 mm Michelin M+S 4x4 235 54,2 mm Tyre & wheel size - steel Make Size Setting Goodyear 205 52,2 mm Michelin 205 52,2 mm Avon 7.50 56 mm Michelin 7.50 56 mm Goodyear 7.50 56 mm Last edited by dorsetsmith on 23rd Dec 2017 5:25pm. Edited 3 times in total |
I'll try find a guide on adjusting them and have go at the other side
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Follow the info Dorsetsmith has posted and your sorted
![]() 2008 SVX 90 2000 XS TD5 90 |
Nice thank you , I'll have a play with the one that's intact if it works, I'll drill out the broken one
Spray plenty of WD40 on the unbroken one first and let it soak in to make it easier. Wheels and tyres look fab
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 ![]() ![]() ![]() |
Hi
How is the noise level compared to the old set? |
I'm driving the noisest car known to man so tyre noise isn't really something I've noticed
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 ![]() ![]() ![]() |
dorsetsmith
![]() Very useful for future changes Thanks Leeroy |
Trying to measure the stop bolt protrusion today, not exactly an easy place to get a accurate measurement. It's around 50mm at the moment , but I could do with working out a way of accurately measuring it before adjusting. I haven't quite wrapped my head around how they work yet either , will wait for a dry day before I have a go at them.
Adjusted one bolt but 50mm bolts are too short to get the required measurement as per the above table .
that's odd from LR work shop manual i haven't try this set up with 265 75 16
Yup, obviously u can get the right length but there is no thread other side to fit a nut
