![]() | Home > Wheels & Tyres > New boots and wheels |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
I just used a longer 60mm bolt on mine , otherwise to get it right nut falls off. I'm not convinced they are locking nuts either. I've just replaced with a new nut for now until I can get some nyloc's.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 818 ![]() ![]() ![]() |
Wheels and tyres look great
![]() I've been running the same size on my 110 for a few years, works well for me ![]() I didn't mess about measuring the lock stops, just fiddled about until I could get my fingers between the tyre and the suspension arms on full lock..... sorted ![]() |
Ian825 Member Since: 31 Oct 2016 Location: East Yorkshire Posts: 11 ![]() ![]() ![]() |
had a ride out since setting them to max bolt with full lock nut & there is no rubbing, need to check for the 20mm clearness when I can get assistance to turn lock to lock but seems about there!
I don't worry about the 20mm just went with fingers in the gap method. No idea if it really needs 20mm minimum or not.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Djcla think that’s a sensible approach to be honest
![]() 2008 SVX 90 2000 XS TD5 90 |
Managed to get the other steering lock bolt out with Stillson's an angle grinder and some help . Steering adjusted both sides and seems ok and not as bad as I thought it would be tbh.
Sorted
![]() Well done ![]() |
