![]() | Home > Technical > Key Fob ID for a replacement..... |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
It needs to be synced with the vehicle, best place to buy is a landrover dealer in my experience
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
are they expensive OOI? 2008 TDCi 2.4 XS CSW
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
YWX101220 - They're about £90 plus programming from Land-Rover.
However you can just buy a second hand Rover fob and get it programmed to the car. Actually the car is programmed to recognise the fobs, they all give out a different code. So long as the fob is a 17TN or 3TXB type it should work fine. Is it your rubber buttons that are worn through? If it is you can buy a new casing and buttons from Land-Rover for around a tenner, just transfer the circuit board over. There are people on ebay who will replace the microswitches on the circuit board if they're faulty. Incidentally, you can just unlock the door with the key, the alarm will sound when you open the door but when it does just put the key in the ignition and start the engine, the alarm should stop as it'll sense the fob being there. |
