Home > Technical > Key Fob ID for a replacement.....
johnnyd
Hi All
Got stuck tonight.....keyfob was very intermittent, just luck I got it to work after dismantling it, replacing the battery, banging it etc......took an hour of Censored about with it.....Got home ok and the spare fob is fine.......hw do I buy a replacement with the same frequency/ID etc ?
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #672093 19th Dec 2017 7:43pm
grafty99
It needs to be synced with the vehicle, best place to buy is a landrover dealer in my experience Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672095 19th Dec 2017 7:48pm
johnnyd
are they expensive OOI? 2008 TDCi 2.4 XS CSW
Post #672097 19th Dec 2017 7:54pm
zsd-puma
YWX101220 - They're about £90 plus programming from Land-Rover.
However you can just buy a second hand Rover fob and get it programmed to the car. Actually the car is programmed to recognise the fobs, they all give out a different code.
So long as the fob is a 17TN or 3TXB type it should work fine.
Is it your rubber buttons that are worn through? If it is you can buy a new casing and buttons from Land-Rover for around a tenner, just transfer the circuit board over.
There are people on ebay who will replace the microswitches on the circuit board if they're faulty.
Incidentally, you can just unlock the door with the key, the alarm will sound when you open the door but when it does just put the key in the ignition and start the engine, the alarm should stop as it'll sense the fob being there.
Post #672153 19th Dec 2017 11:08pm
