Home > Technical > Leaking sides to rear tub sealing advice
barbel jim
My new Td5 hardtop had a multitude of water leaks which bar 1 I have solved. I keep getting puddles appear in the rear. It is leaking through the foam seal. Everything is bolted down tight but there is a noticeable bend inside, as in its tighter either end. The obvious thing to do would be replacing the seal. However I'm a little worried that will not cure the problem due to the deflection. Is it worth using a mastic to seal externally , and if so any recommendations ??
Ta in advance Thumbs Up
Post #671677 18th Dec 2017 12:23pm
grafty99
I would be inclined to put more bolts in Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671739 18th Dec 2017 5:06pm
grafty99
Having said that I put new seals in mine when I rebuilt after the respray. They're really thick (40mm or so) 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671740 18th Dec 2017 5:07pm
barbel jim
It has the correct bolts and brackets George. Additional ones would have to be drilled, not the easiest and permanent holes Big Cry I'm sure I've read somewhere on here , someone used sikaflex? I know k9(mal) was an advocate of it. The only problem is splitting at a later date! It's just one corner and under the rear quarter light.
Post #671782 18th Dec 2017 6:59pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I would unbolt it, replace the seal, and then check for rust/other issues. the standard seal is good except for the one spot by the seam of the cappings. you can add a bit of sealant, but something is cleary wrong fundementally if it's leaking.
It's an hour's work and parts are cheap. V8 90...WIP
Post #671785 18th Dec 2017 7:09pm
Masking tape, upper and lower part of gap, apply silicone liberally in one big line with BARREL gun (skeleton guns are a waste of money and effort) lick finger and smooth it in in one big line. Peel masking tape off.
Post #671786 18th Dec 2017 7:10pm
Sulisuli
Sikaflex mastic is a great product we use it a lot at work, it’s easy to finish (like bathroom sealant) but does stick like Censored to a blanket Laughing very waterproof, very flexible, very good product Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #671787 18th Dec 2017 7:10pm
Here was my result.
Post #671788 18th Dec 2017 7:12pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Jim, I had a leak under the rear quarter light (near side) and I thought it was the tub seal, put some dum dum around the inside of the light, no more leaks, worth a try Very Happy Cogito ergo sum
Post #671789 18th Dec 2017 7:14pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Greeni has made a very neat job, But I would put new a seal in as mastic is quite severe
Post #671792 18th Dec 2017 7:22pm
barbel jim
GREENI wrote:
Here was my result.
Knew I'd seen it somewhere Bow down
Thanks Greeni.
Trade tip - Better than licking your finger, use a spray mister, with some water and a few drops of washing up liquid Thumbs Up
Post #671796 18th Dec 2017 7:28pm
My fingers usually are sticky from sticky buns. I appreciate the tip though Thumbs Up
Laughing
Post #671800 18th Dec 2017 7:41pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I do the same as greeni but use a polymer sealant instead of silicone. I also do the front bulkhead.
Post #671822 18th Dec 2017 8:30pm
zsd-puma
Plenty of different brands of proper car body sealer available for the job.
Silicone is a nightmare if you ever have to have any paintwork done.
Post #671925 18th Dec 2017 11:55pm
barbel jim
Quick update,
Rear tub sorted, new seal sorted that. Now found another leak Big Cry
Drivers side roof to windscreen , leaking in the corner where the dum dum has deteriorated and disappeared, dug it out and cleaned up and resealed with sika ......... fingers crossed
Post #676341 6th Jan 2018 1:52pm
