Home > Technical > Swivel housings overhauled
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
At last have overhauled the swivel housings, and she drives a dream. Renewed the swivels with Britpart Kits from first four. The kits included Teflon swivel with top pin and sims ,main seal ,seal for ABS ,Timkens top and bottom bearings and one shot grease.Had to buy the inner seal as a extra. Also fitted new Timkens main bearing sets. Had a problem removing the off side drive flange which was solidly rusted to the shaft so had to cut it off after hammering and heating it. So purchased a new cv joint for the off side and drive flange. Also had a leak on the near side calliper so made the decision to fit new stainless steel pistons and seal kits to both sides. Fitted new bolts where needed also. In for penny in for a pound fitted new discs and pads both sides as the near side pads where contemplated with brake fluid.
Post #671394 17th Dec 2017 7:43am
grafty99
Nice one Thumbs Up should last a while now! I'm planning on stainless pistons for my brakes at some point - a very worthwhile upgrade Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671396 17th Dec 2017 7:51am
agentmulder
Kuwait
I did a similar overhaul last year, quite a long session but very rewarding.
Nice work Thumbs Up Solved the bowel problem, working on the consonants...
Post #671402 17th Dec 2017 8:27am
srod
How long did the job take?
Post #671403 17th Dec 2017 8:56am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looks good Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #671404 17th Dec 2017 9:01am
Gozy
The time wasn’t an issue because I had another vehicle to use. Did the work at weekends. Maybe able to complete the job in two or three days if all goes ok
Post #671511 17th Dec 2017 6:11pm
Alex1976
Looks good!
I did my swivel rebuild a last year ago and it does transform the drive when it is all new and set up spot on.
Very satisfying job.
Thumbs Up
Post #671521 17th Dec 2017 7:05pm
