Home > Td5 > Whilst the dash it out....
isacs
So I need to take the dash out...again. So this time to try a future proof having to do it again in the future.... any suggestions of things to just get done whilst it’s out??
Greg
Post #671458 17th Dec 2017 3:44pm
ibexman
Dynamat
Post #671459 17th Dec 2017 3:45pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If your wipers are sloppy, as most are, perhaps consider changing the wiper wheel boxes... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #671468 17th Dec 2017 4:18pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Replace the wiper park switch while you're at it, and the wiper cable. Ours broke without a warning when we were on our way to holiday, so we spend an evening repairing it on a cold and wet parking.
I also added a second windscreen washing unit earlier. Moved the middle one to one of the blanked of holes and added a second washer unit in the hole on the other side. You'll need some tubing and a T-piece and evidently a second unit. I used a generic one from paddock which is annoyingly just a little bit shorter that OEM. They're actually useful millimeters which made it quite a fiddly job.
Also replace the wiper interval switch by a programmable one, it's behind the clocks. One of the things that you'll appreciate every single time that you use it
Joris
Post #671480 17th Dec 2017 5:14pm
bluebottle
Another 12v socket? Always handy in this age of smartphones with 12h battery life!
Post #671514 17th Dec 2017 7:30pm
isacs
Care to elaborate??
Post #671839 18th Dec 2017 9:25pm
donmacn
^^^^ I wonder if he means the intermittent wipe relay?
On a Tdi you can fit an adjustable timer relay instead of the LR one, and then adjust the timing of the intermittent wipes. I think it's a VW/Audi part. I've done it on mine, but on a 300tdi, this relay is behind the fuse box rather than the clocks.
It's a dead simple, but really effective mod. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #671846 18th Dec 2017 9:40pm
Vogler
Indeed, sorry for the translation error.
Did a quick double check because it hasbeen a while:: the wiper intermittent relay on post 2002/15p Td5's (like ours) is behind the speedo, earlier models have it with the other relays.
It's a red Lucas one. If you swap it for this Bosch relay (or the Volkswagen 99 relay IIRC), then you can determine the interval. Push the wiper stalk down, up and down and it continues with the same duration as you took between the up and down, as long as it's shorter than 20 seconds. Standard interval when you just push the stalk down is 6 seconds.
Hope that's clear.
Greetings,
Joris
Post #671918 18th Dec 2017 11:08pm
JWL
You could do the dual windscreen washer jet mod, take the original out of its central position and with another one place them in the other position holes for the wipers when in the LHD position. Put a "T" pieice in the feed pipe and a bit of new pipe to each new jet.
Post #671926 19th Dec 2017 12:24am
4RF RDS
Like this.... Thumbs Up A bit covered in salty spray but you get the idea, its a great and simple yet inexpensive mod.
1967 MGB GT
Post #671927 19th Dec 2017 12:33am
isacs
Would it be worth adding a heated screen loom?
Post #672028 19th Dec 2017 4:13pm
4RF RDS
It would, especially if you have a heated screen Rolling with laughter Seriously though, yah if you intend to do that it would be. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #672030 19th Dec 2017 4:32pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Nice suggestions, I'm definitely going to put the extra windscreen washers on my list of things to do Thumbs Up
There's a mod you can do to the vents which is to stop water ingress, i'll see if I can look it up 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #672031 19th Dec 2017 4:33pm
isacs
The winter mods are springing to mind, side demister kit is needed.
Post #672091 19th Dec 2017 8:37pm
