Home > Technical > head light bulbs
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
head light bulbs
hi guys i just want to clarify i want to change the bulbs h4 as long as i change them to the same wattage 55\60 watts but a higher burning gas xenon it will not burn out my switch
Post #671048 15th Dec 2017 12:55pm
Devon-Rover
If you keep the same wattage then the current load through the switch will be the same. Thumbs Up
The switch will melt in it's own sweet time anyway. Whistle Laughing Wink Thank land rover for that.
Post #671049 15th Dec 2017 1:00pm
ericvv
Re: head light bulbs
Of course not.
Did I say that?... Crying or Very sad Shocked
Rolling with laughter Rolling with laughter Rolling with laughter You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #671067 15th Dec 2017 4:02pm
grafty99
Laughing Plenty of switches have failed with standard wattage headlights (mine included before I went LED.)
But a good standard wattage lamp is the PHILLIPS 130% Extreme vision. I have them in my motorbike and they're excellent and have lasted well so far Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671075 15th Dec 2017 4:57pm
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
+1 PHILLIPS 130% Extreme vision
Post #671077 15th Dec 2017 5:01pm
+1 From me too. But the Loom mod is the way to go also, combine the two and you will be very impressed. WeWillWin🇬🇧🇺🇸
Post #671079 15th Dec 2017 5:09pm
L110CDL
I'm using the 150 extreme vision and i'm well impressed with them and i have got the loom upgrade fitted as well Very Happy Very Happy Clayton.
Keeper.
Post #671360 17th Dec 2017 12:11am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Yes well worth replacing the loom as a permanent solution.
In fact it’s my job for today as my switch started playing up last week.
I did fit some unrated bulbs last month so these might have pushed it over the edge. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #671436 17th Dec 2017 12:47pm
zsd-puma
just replace the headlamp loom with one of the relayed ones that take a feed direct from the battery. It'll probably be as good as the uprated bulbs on the standard set up and you wont melt the switch.
Post #671477 17th Dec 2017 5:04pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Added to that crystal headlamps also deliver a better yield. And they are almost indestructable - the headlights, blinker and the BBUS were the only thing that remained whole when a drugged and drunken twit slammed into the left wing of our 110. Literally all other parts of the wing had to be replaced.
Joris
Post #671483 17th Dec 2017 5:25pm
L110CDL
I made a mistake and i am using these.......................................................
Still well pleased with these Cool Clayton.
Keeper.
Post #671544 17th Dec 2017 9:27pm
kingsley
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Hi Guys,
Hope you all having a great xmas. Looking for some advice please, I have no brake lights on my defender 90 xs TD5, High level brake light is on all the time and also rear tail lights but very dim, no change if I put the lights on though.
all very strange, please help..
Post #673428 26th Dec 2017 1:51pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Sounds like an earth problem
Post #673429 26th Dec 2017 1:58pm
kingsley
Thank you, would you know where I should start to look for the earth problem?
Post #673431 26th Dec 2017 2:05pm
shropshiredefender
Remove each tail/side lamp by undoing the 2 screws that hold them to the body, then unplug the wiring. Be careful not to let the plug disappear into the bodywork!
Try removing each bulb and cleaning the bulb holders and bulb contacts with WD40 and wet and dry paper.
While you have the lamps out clean each plug contact as well.
While you're at it you might as well do the indicators too.
Sometimes the bulbs are corroded and very difficult to remove without breaking, so it's as well to have spares before you start.
Doing the above is a good starting point and often solves the problem.
Post #673432 26th Dec 2017 2:24pm
