Home > Technical > Brake caliper refurbishment 110 2004 hicap
Hawksthorn
United Kingdom 2004 Defender 110 Td5 HCPU Bronze Green
I have removed all my calipers and have had them sandblasted, looking to repaint then replace seals and pistons, with stainless ones,
What kit would people recommend, and from where?
regards
David
Post #671066 15th Dec 2017 3:59pm
bankz5152
MPS do a stainless set since youve already started but its often cheaper or the same price to buy new!
Post #671072 15th Dec 2017 4:37pm
Devon-Rover
Most the usual suspects do stainless pistons and they all look alright not heard any problems.
I used IIRC EAC parts stainless pistons and Definitely use Genuine seals and retainers as a few pattern one's have been reputed to not fit. and IMHO I would risk such a critical component to skimp on quality.
Post #671114 15th Dec 2017 8:36pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
I split the calipers when I refurbished the brakes of our MY06 110 and bought stainless pistons and new gallery seals (the rubber rings or tubes between the two caliper halves) on shop4autoparts.net. They're about the only ones I know of that have the gallery seals on offer.
If you need the new gallery seals than make sure not to throw away the small tubes that are inside the longer seals of the front calipers. They're not included in the new ones.
Greetings,
Joris
Post #671136 15th Dec 2017 10:01pm
agentmulder
Kuwait
If you're pressed for time and/or your parts supplier is far away get yourself a spare retaining ring or two, I bent one beyond repair in the installation (it was the last, I got too confident...)
Also it's as good a time as any to invest in a brake union spanner.. Thumbs Up Solved the bowel problem, working on the consonants...
Post #671148 15th Dec 2017 10:47pm
Hawksthorn
calipers
Thanks for the info guys,
I have a lot of other bits to purchase, as its a complete vehicle refurb, stub axles all round,front swivels, suspension bushed all round etc etc, so any suggestions on the best supplier would be appreciated, bearings and seals I am going to oem's or even genuine if its affordable, again any suggestions would be great.
Many thanks
David
Post #671199 16th Dec 2017 11:51am
agentmulder
Kuwait
Timken bearings
Corteco seals
Paper gaskets just go Bearmach
Bearmach also ok for the swivel pin/bearing sets
In general I avoid britpart like the plague but britpart 'OEM' swivel housings and flanges are actually pretty good
For brakes I went all genuine
Lots of parts places, personally, I use landroverworkshop.com to find parts and compare prices, then invariably go to brit-car.co.uk or paddock to buy them. Solved the bowel problem, working on the consonants...
Post #671204 16th Dec 2017 12:21pm
