Home > Puma (Tdci) > Symptoms/Causes of Turbo Lag in a Defender TDCI 2.4/2.2
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi Guys,
Is there a definitive list of symptoms and causes for Turbo Lag in a TDCI 2.4 engine?
How do I avoid Turbo Lag? (Is it even possible?)
Thanks
Post #669100 5th Dec 2017 11:14am
xtreme2252
Australia
Replacing centre muffler with straight through pipe is supposed to improve turbo lag
See Below
These are 304 stainless steel exhaust silencer replacement pipes. They are designed to directly replace the front silencer in your exhaust system. Once replaced the pipe will give your vehicle more power or reduced fuel consumption with only a small increase in cabin noise. CNC mandrel formed for a perfect fit with laser cut flanges, the pipes have a sateen finish, deep luster appearance. Quick and easy to install.
Post #669261 5th Dec 2017 10:59pm
Arsath
Did you miss the pictures? It looks like either nobody suffers from turbo lag or not many people have solutions.. Very Happy
Post #669854 9th Dec 2017 1:25pm
zsd-puma
Well the 'symptoms' of turbo lag are simply you put your foot down and nothing happens, then woosh loads of power.
My 2.4 seems fine, no different to any other modern turbo diesel.
In general the causes of turbo lag on a modern Common rail diesels are dirty or damaged mass airflow meters (or the wiring), or a faulty acutator on the turbo if it has variable geometry.
Post #669878 9th Dec 2017 5:01pm
Arsath
Thanks, that gave me some perspective.
Post #670448 12th Dec 2017 8:03am
dgardel
Italy
Re: Symptoms/Causes of Turbo Lag in a Defender TDCI 2.4/2.2
Arsath wrote:
Hi Guys,
Thanks
- MAP
- PCV
- Vane actuator Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #670583 12th Dec 2017 7:26pm
LR90XS2011
mines a 2.4 2011 standard tune no noticeable turbo lag , smooth linear torque from idle to 4000rpm just the noise varies DEFENDER 90 TDCI XS,
Post #670587 12th Dec 2017 7:33pm
Faulty clutch switch can also have similar symptoms. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #670599 12th Dec 2017 8:49pm
