![]() | Home > Puma (Tdci) > Symptoms/Causes of Turbo Lag in a Defender TDCI 2.4/2.2 |
xtreme2252 Member Since: 15 Apr 2015 Location: Melbourne Posts: 29 ![]() ![]() |
Replacing centre muffler with straight through pipe is supposed to improve turbo lag
See Below These are 304 stainless steel exhaust silencer replacement pipes. They are designed to directly replace the front silencer in your exhaust system. Once replaced the pipe will give your vehicle more power or reduced fuel consumption with only a small increase in cabin noise. CNC mandrel formed for a perfect fit with laser cut flanges, the pipes have a sateen finish, deep luster appearance. Quick and easy to install. |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 ![]() ![]() ![]() |
Did you miss the pictures? It looks like either nobody suffers from turbo lag or not many people have solutions..
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Well the 'symptoms' of turbo lag are simply you put your foot down and nothing happens, then woosh loads of power.
My 2.4 seems fine, no different to any other modern turbo diesel. In general the causes of turbo lag on a modern Common rail diesels are dirty or damaged mass airflow meters (or the wiring), or a faulty acutator on the turbo if it has variable geometry. |
Thanks, that gave me some perspective.
- MAP - PCV - Vane actuator Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3655 ![]() ![]() ![]() |
mines a 2.4 2011 standard tune no noticeable turbo lag , smooth linear torque from idle to 4000rpm just the noise varies DEFENDER 90 TDCI XS,
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Faulty clutch switch can also have similar symptoms. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
