Home > Puma (Tdci) > Compression Test Specs? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Those all look very low readings for a 2.2,
You should be seeing anything between 350 - 400psi for a healthy engine! Why was the head replaced? Did you do any work to anything else, could it have been over fueling at some point, I wonder if the Bores and rings are ok? Which cylinder was reading 110? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
11th Dec 2017 7:18am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
110psi is getting close to an old Petrol lawnmower
11th Dec 2017 12:03pm |
Yes, not a good reading by a long shot! 80" 80" 86" 88" 90"
11th Dec 2017 12:50pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
I wonder if your valves are actually closing? Could the timing for the camshafts be slightly wrong? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
11th Dec 2017 4:26pm |
