Home > Tdi > Is this a 300Tdi?
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Is this a 300Tdi?
Hi all,
May I know if this is a 300Tdi please?
Many thanks in advance!
APK
Post #669745 8th Dec 2017 3:25pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Yes it is, at least the engine has yellow oil filler and dip stick and 300tdi plastic cover. Thumbs Up Just because you're offended doesn't mean you're right.
Post #669746 8th Dec 2017 3:28pm
APK
shropshiredefender Thank you! Bow down
How much would you value an unmolested 300Tdi 110 with slightly over 100k on the odometer?
I know this is very subjective, but I hope to get a range before I drive for 3 hours to see it.
Rust looks minor, lots of panel dents, but comes with service history for 15+ years so I know its not stolen.
Any idea how I can tell if the engine is in good working order? As you can probably tell, I have no experience with this sort of thing as I own a TDCi Laughing
Post #669748 8th Dec 2017 3:36pm
mini Anaconda
Do you have any other pictures? It's hard to gauge value as there is so many determining factors. (I have a 200Tdi).
I remember looking at this vehicle online somewhere (eBay?) as the shiny black top intercooler hose is familiar and what could be oil/diesel on the left hand side of the engine cover.
Look out for leaks, smoke and how well it pulls if you test drive it, and how regular the service intervals have been.
Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #669756 8th Dec 2017 4:28pm
APK
Thank you mini Anaconda. Agreed, "The true price of any item is what somebody is willing to pay for it."
The asking for this is over 10k, I wanted to go back with a reasonable offer. Are there any big repairs that come at the 100k mark for the 300Tdi?
In addition to what you mentioned, I assume the state of the chassis matters as well? I got a rust treatment done on mine when it was just 1 week old, I doubt most owners cared for that in 94/96.
I saw a beautiful blue county 300tdi go for £8995, 1 month ago but Nene overland has one for 21k+ Shocked
http://www.dillers4x4s.co.uk/land-rovers-f...-value.htm
Post #669761 8th Dec 2017 5:08pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Shinny intercooler hose would indicate rubbing on the bonnet from I can see from the pic, you can see the two coolant hoses have been zip tied together, make sure you check the smaller one for wear underneath, people tend to lean on it and damage the plastic bracket that holds it, this causes the pipe to rub against the water pump pulley.
300tdis are fairly bulletproof, water pumps and belt tensioners seem to be the main engine items I replace, if you take along a 15mm socket and long breaker bar you can release the tension on the belt and check those two items for play.
Corrosion on the bulkhead and chassis need to be checked in the normal places and seatbelts for damage against the locking mechanism.
Oh another often over looked item is the four rubber mounts for the air filter housing, these are often perished. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #669771 8th Dec 2017 6:01pm
jst
its def a 300tdi.
i am yet to see one with the original underbonnet soundproofing that doesn't have a shiny top inter cooler hose section. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #669792 8th Dec 2017 8:28pm
APK
Thanks all Thumbs Up
Please check PM. Best, APK
Post #669826 9th Dec 2017 9:11am
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Everything looks in place, , the next mechanical issue at that milage will be the clutch arm [ slave rod busts thru,] usually about 130,00 miles, mines did and a few friends at 140,000. otherwise great motors, mines is on 345,000 miles,
and have full documented sevice history, still on the original Turbo, and injection pump,
Post #670427 11th Dec 2017 11:39pm
L110CDL
and have full documented service history, still on the original Turbo, and injection pump.
Totally agree with you there as i'm not to far behind you with all the same info Wink Clayton.
Keeper.
Post #670803 13th Dec 2017 9:12pm
Procta
yeah that's a 300 as others have mentioned, the 200 is more further back and more lower down. Me and my dad spent an hour comparing the two engines.
A few things are the same but not in the same place, also looks like its had the EGR binned and blanked, That was one of the 1st things I did with mine under the bonnet, was bin that off. So looks like its been looked after straight away.
I had a major leak at the intercooler end, who ever had it before me had the pipe welded for some reason.
Also check if its got a cat in the system, if it has, get that binned straight away. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #673237 25th Dec 2017 1:53am
