Home > Wheels & Tyres > What tyres for mud and road
Shropshire Lad
Hi Guys
Running on the standard grabbers but don't really rate them. I use mine on road and on the farm and I find the standrad tyres lack grip. Can anyone suggest any tyres that run well on mud without too much deterioration in ride quality on road.
SL LR 90 XS GONE! Hurrah!
Post #6665 29th Jan 2009 2:20pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I run BFG MUDS (255-85) on the 90 and BFG AT (285-75)
Both I find good in the slipery stuff but the muds are better and AT are quieter on road.
Boy
Post #6666 29th Jan 2009 2:48pm
Shropshire Lad
Thanks Boy.
And you find the ride on these ok on tarmac?
Post #6667 29th Jan 2009 3:15pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi use BFG Muds on 110 and they arefine on the road, just take it easy in the wet. Road noise is OK AT's are quieter on road but not as good in the mud, so go for the Muds.
Mark
Post #6668 29th Jan 2009 3:38pm
Genis
South Africa 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Boy, do the 255/85 Muds rub anywhere on the vehicle. Is your vehicle standard or does it have a lift?
Post #6669 29th Jan 2009 3:59pm
Laurie
I rate Goodyear MT/Rs very highly.
Excellent in the mud and well behaved on tarmac.
Post #6670 29th Jan 2009 4:23pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
How much of each do you do?
BFG AT or Cooper ST should be plenty good enough unless you're doing serious mud (comp, pay and play). They'll both be much better than the standard GGs but you'll still get decent performance on road.
Safety-wise, the most important thing to do is not to compromise your on-road performance (esp in wet).
I'd plump for AT over mud.
Post #6671 29th Jan 2009 4:42pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
BFG MT every time Thumbs Up they are great on road and fantastic offroad. Anything else is a compromise Very Happy
Post #6677 29th Jan 2009 6:24pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
BFG muds work really well for me. Had some on my last 2 Defenders and they are currently fitted to my new one. I use my vehicle as a daily commute and also it sees lots of mud and rubbish all year round. I can't rate them highly enough.
255/85 will give you a little more height and still a good width ratio and are ideal for everything. I run 265/75/16 on mine and have had no problems.
I can also recommend Cooper ST's as well. Excellent tires with a fantastic compromise in tread pattern between AT and MT. I would recommend you have a look at these too. Unless you are planning on driving through the really gloopy stuff, ST's are great and will outperform an AT.
Post #6678 29th Jan 2009 6:30pm
alantd
Again - it all comes down to how much extra grip you need on the farm.
If you're pulling heavy loads in really soft ground then MTs or STTs would give you significant extra grip. However, they're intended for 80% off-road use and on-road you'll suffer more noise, less fuel efficiency and, most importantly, a greater braking distance (especially in the wet).
BFG AT is more like 50:50 and a better compromise IMHO.
Cooper ST is in-between the two.
Post #6695 30th Jan 2009 11:19am
Shropshire Lad
Thanks all for the advice. As ever brilliant!
I reckon I use mine about 70% on road and 30% on field and track. I usually tow a heavy duty twin axle trailer on and off road loaded to a total weight of 2.5 tonnes. From what you are all saying it seems that an A/T would be my best bet? I certainly don't want to compromise braking distance on road it can be hairy enough in the wet with a full load on at the best of times....
Cheers one and all
Shropshire Lad LR 90 XS GONE! Hurrah!
Post #6696 30th Jan 2009 11:59am
Landy nut
Based on the description of what you have just described, I would recommend going for the Cooper ST as it will give you most of the advantages of both MT's and AT's. If you ever have to venture into a field rather than just tracks, I would opt for the extra grip it will give as the terrain from swithching between the two can change dramatically from a wet and slippery track to a gloopy field. It is better to have more than you need when you dont need it rather than not enough when you do!!!
Best wishes
Landy nut
Post #6708 30th Jan 2009 5:48pm
Shropshire Lad
Thanks Landy Nut. I will have a look at the Cooper ST's. Never run on them before but seems they've been suggested in response to this post a few times now. LR 90 XS GONE! Hurrah!
Post #6709 30th Jan 2009 5:58pm
AndrewS
BFG MT Thumbs Up
Post #6716 30th Jan 2009 10:53pm
The Boy
sorry mate been away from the pc. Yes I have a 2" lift on the 90 but not on the 110 with the 285's.
Post #6720 31st Jan 2009 10:16am
