Home > V8 > 3.5/3.9
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
3.5/3.9
Question...
Has anyone done, or know if you can happily run a 3.9 on carbs (SUs)?
I've been offered a good 3.9 engine with a fried ecu, and injectors,
It's a low mileage engine at 64,000 miles.
I'm wondering if the SUs would cope, or need re jetting?
Cheers 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #669176 5th Dec 2017 5:47pm
Devon-Rover
Hi Half an answer as I have lost / forgotten the info.
Yes you can but it will need different needles and springs and possibly a bit of time with a dyno and wideband exhaust gas analyser to check the mixture and fine tune the needles to get the best mixture.
Post #669212 5th Dec 2017 7:37pm
ian series 1
Thanks for confirming what I had thought Wink
I was thinking maybe a phone call to Burlen?
https://burlen.co.uk/
I'm sure they could shed some light on what would be needed?
Post #669213 5th Dec 2017 7:47pm
JeremyJ
Yes, will work. My 2b is running a 4.6 on SU’s
Post #669217 5th Dec 2017 8:08pm
ian series 1
is that on standard carbs Jeremy?
I suppose I ought to just get it, put the carbs on and run it up,
And see how it runs and sounds? 80" 80" 86" 88" 90"
Post #669225 5th Dec 2017 8:34pm
JeremyJ
Yes, but I can’t remember which needles are in them.
What about keeping the efi?
Post #669228 5th Dec 2017 8:44pm
ian series 1
I'm a big fan of the twin SUs, there is just something about them?
Not a fan of Strombergs, had nothing but trouble with them on an old 2 door RR,
the engine I've been offered is being ditched because of ECU malfunction,
I thought it would be a fun project to strip and rebuild it on carbs.
(Not like I've enough to do).... Neutral Laughing
Thumbs Up 80" 80" 86" 88" 90"
Post #669241 5th Dec 2017 9:05pm
mikeh501
wont it need a different front end with distributor? and a diff intake manifold etc?
Post #669378 6th Dec 2017 7:58pm
ian series 1
Yes, there is a fair bit to swap over,
But all doable. 80" 80" 86" 88" 90"
Post #669379 6th Dec 2017 8:02pm
oneten110
Why not just stick with the EFi. Sourcing a replacement ECU shouldn't be a problem and a set of injectors can be repaired in the same way as a set of diesel injectors can.
try having a chat with these people.
http://www.tornadosystems.com
Post #669512 7th Dec 2017 10:38am
ian series 1
I want it to keep it simple, it's for a series 3, 80" 80" 86" 88" 90"
Post #669514 7th Dec 2017 10:51am
oneten110
Honestly it is probably simpler to set up than carburetters.
I took my 3.5, that I had fitted with a 3.9 EFI system, to Tornado and they set it up in about an hour, managing to double the power output at the same time
Post #669517 7th Dec 2017 11:12am
ian series 1
I did think about going EFI when I started the project,
But as I said, i much prefer them on carbs.
I don't think anything can beat it when they are set up properly Wink 80" 80" 86" 88" 90"
Post #669520 7th Dec 2017 11:28am
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
This is your man for advice on SU's
http://www.johnealesroverv8.co.uk/ Richard
Defender 90 SVX
Post #669895 9th Dec 2017 6:14pm
