![]() | Home > Maintenance & Modifications > Brake Caliper Reconditioning |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
If its for a Defender just buy new ones. Paddocks have genuine AP ones for £160 a pair
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Agreed, just buy new AP (OEM) ones and sell off your ropey old ones for someone else to refurb.
I did it last year, got about £60 for my old calipers. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Go for stainless cylinders, see http://www.defender2.net/forum/topic32525.html for supplier.
Merlin |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
They aren't too difficult to recondition yourself to be honest. Depending I suppose if you need the vehicle as it probably takes an hour a caliper plus removal, fitting and bleeding
![]() Unless you aren't happy doing it yourself in which case I would try a local motorfactor or the above mentioned and buy replacements. Some factors will give you some money back if you return the old calipers (surcharge on a recon unit) 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
