Home > Technical > 2009 2.4 TDCI Defender Starting Issue (10AS? IPAC? ECU?) |
olliecracker Member Since: 18 Nov 2017 Location: Gloucestershire Posts: 19 |
Click image to enlarge Yeah Showing just over 200Rpm on turn over |
20th Nov 2017 9:38pm |
Ahh okay! Thankyou!,
I'll look at getting one tomorrow! |
20th Nov 2017 9:39pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
Somebody diagnosed my cam sensor using the Lynx, but I don’t know how to do it. I would try to do that before buying a sensor in case it’s money wasted. 2007 110 TDCi Station Wagon XS
20th Nov 2017 9:44pm |
Ahh okay, I'll have a play tomorrow after work! - If not, I'll just get one from GSF car Parts
Thank you |
20th Nov 2017 9:55pm |
Hi again!
This afternoon I went back to the Landy... Fired up straight away... No problems at all! Haven't touched anything. I then went on to look at the cam sensor and all looked fine when checking with a multimeter. Could take it to work and check with an oscilloscope but I'm pretty sure it's okay. After, I disconnected the immobiliser coil (AMR4897) that fits around the ignition barrel and just as before, it fired up again.. Does my immobiliser do anything? - looking in lynx diagnostics, the passive immobiliser and theft system are active. But I've disconnected the only part that would actually recognise the key. I probably will go back to the Landy tomorrow and it won't start Nanocom should be arriving on Tuesday! Thanks, Ollie |
24th Nov 2017 5:49pm |
But I've disconnected the only part that would actually recognise the key. (not so all in the way its set up )
YES it run your interior light or not |
24th Nov 2017 6:00pm |
Does an immobilised 10AS stop the engine from cranking? - If it does then I can rule that out and just check the signal is getting to the ipac.
Update: Plugged in the Nanocom today and the Passive immobiliser is disabled, and it's set up for TD5/MEMS. The lynx diagnostics read that the passive immobiliser was active but I'm going to trust the NANOCOM |
27th Nov 2017 7:41pm |
2 faults found on the Nanocom
28th Nov 2017 7:20pm |
Fixed!
It was the IPAC not passing the signal onto the ECU inttermitently! Got around it with a mod and now it starts everytime |
30th Nov 2017 9:56pm |
Exwirus Member Since: 11 Dec 2017 Location: Bydgoszcz Posts: 7 |
Hi olliecracker. Could you explane how exactly you fix the problem? Seams i have got same issue what means IPAC?
11th Dec 2017 7:57am |
good |
11th Dec 2017 8:03am |
Ok i uunderstood that IPAC is instrument cluster, right? I checked signal from AS10 into IPAC and it's changing when fob is close to immortal coil. But I don't know how to check outgoing signal to ECM? Signal is 0.9V all the time.
11th Dec 2017 2:41pm |
I replaced also CMP sensor. No results unfortunately
11th Dec 2017 2:43pm |
Thanks a lot for advice and help. Was the same issue lack mobilisation signal to ECM. Solved with the IPAC bypass.
13th Dec 2017 8:31pm |
