Home > Technical > Big problem
BigMike
Big problem
Am hoping someone can help. Were in Spain om way to morocco.
When rmthe vehicle is hot and under load there is drastic power loss every 2 seconds . It's worst going up hills. Stop abd let it cool for ten mins and it's then ok for about 20 mins then does it again the engine stays on so it's not ignition related and the diagnostic us showing no faults
Anyone any ideas? Seems electrical or electronic to me so can someone please also tell me how to reset the ecu? Any help would be great
Post #66774 9th Apr 2011 9:27pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
sorry to hear about your problem. i have no idea as such on a defender but i had similar problem some time ago when hot under load and it was fuel starvation.
just a thought.
good luck BM52
Post #66781 9th Apr 2011 10:39pm
AndrewS
What winch have you got fitted and where is your numberplate located Question Or is the air flow to the radiator restricted Question 130's have feeling's as well you know Smile
Post #66785 9th Apr 2011 11:04pm
Grockle
is the fuel filter clean ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #66796 10th Apr 2011 8:09am
TJ101
Not good Mike,,
Does sound like fuel related (under load, and up hill)
Presuming the temp gauge is reading normal ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #66798 10th Apr 2011 9:10am
Anderzander
All I can suggest is the basics:
Fuel filter, spray some contact cleaner in the ECU plug, the fuel rail plug, the throttle potentiometer plug and the MAF plug. And also check the wiring on those.
With the temp going up though I'd look at the cooling mainly - is your radiator full of mud and dust? Is it obstructed by your bumper? Does having the heater inside on full blast make a difference? Is the system pressurising? Is there an airlock? Enough coolant?
Is the turbo on a Tdci water cooled? Have you had a remap?
Post #66799 10th Apr 2011 9:27am
BigMike
Cheers guys. Seems it was fuel related and is pretty much ok now. Having said that (Andrew) there is also the possibility of radiator as it got better into the night. Plate is on the front attached to the fairlead, might remove it in a bit. However, the temperature gauge never moved and there are no fault codes?
Post #66824 10th Apr 2011 5:19pm
BigMike
Stephen, no remap, no mud in rad. Coolant level ok.
Post #66826 10th Apr 2011 5:24pm
BigMike
Oh and I managed to leave a bottle of coolant on the boat but I guess I could just use water if neccessary
Post #66827 10th Apr 2011 5:29pm
MK
The temp gauge does not move up from the middle position between ca. 85 and 110�C or so. Can u check the actual temp while driving? Puma 110" SW
Post #66829 10th Apr 2011 5:36pm
BigMike
Could do yes. Just means driving with the obd key in place
Post #66830 10th Apr 2011 5:37pm
leeds
The standard Land Rover temperature gauge is about as much use as a chocolate fireguard.
Coolant boils at between 106-120C dependent on concentration and pressure. The standard Land Rover temp gauge does not shift from normal position until 96C has been reached.
On our overland vehicle we have an Engine watchdog fitted. I have set mine to give an audible alarm at 96C well below the boiling point of plain water under normal pressure. It has saved us from a serious problem once when I had a pinhole rubbed into top of rad. It rarely triggers and if it does I just watch the world go by for 20 minutes.
Will be fitting one to the Puma as well.
Sorry Mike can not help you with your particular problems.
Brendan
Post #66831 10th Apr 2011 5:43pm
BigMike
Cheers Bren.
If I take off the battery leads to reset the ecu can someone please remind me how to input the eka code?
Post #66832 10th Apr 2011 5:50pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi Mike,
How hot is it where you are driving?
I wonder how hot your intake temperature is getting to ? ( not engine temp ) There maybe something in the ecu which reduces power if the temp gets too hot.
Just another thought.
Steve
Post #66839 10th Apr 2011 7:42pm
BigMike
Thanks again for all the replies, just found some wifi in zagora. Took off the tanks and the pick up was clogged. All ok now.
Post #67794 18th Apr 2011 2:33pm
