Home > Tdi > oilpressure warning light
juko
Netherlands 1998 Defender 110 300 Tdi HT Coniston Green
My oilpressure warning light goes on when i have driven for about 20-30 km and i park the car. When the engine runs stainonary the oilpressure light goes on. When i rev the engine a little bit iit goes out. I had this about 4 weeks ago, then it stops until today. It started again. Could it be the sensor? or do i have to be worried about the pump? Oil level is good, no oil leaks. Is this a familiar problem?
Post #667320 27th Nov 2017 5:43pm
LR90XS2011
change the oil pressure switch first, if you can find an oil pressure gauge fit this and see what pressure you have, after that its the pump or engine wear, but a gauge will tell you what is happening and when. DEFENDER 90 TDCI XS,
Post #667342 27th Nov 2017 6:21pm
Devon-Rover
Rear camshaft bearing can shuffle out of position, you usually get this as a first sign before the light being on all the time at idle before it stays on all the time. After checking the sensor is fine I would pull off the side plate to have a looksee.
Post #667366 27th Nov 2017 7:13pm
juko
i am going to the garage tomorrow. Hope it will be an easy sensor replacement.
Post #667395 27th Nov 2017 9:16pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I had a very similar issue, solved by a replacement oil pressure switch 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #667414 27th Nov 2017 10:17pm
juko
thank you all for your input.
Post #667453 28th Nov 2017 7:10am
