![]() | Home > Technical > 2011 MY Wiring Diagram |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Tim...
I've got the wiring diagrams for VIN 751063 onwards, although I don't know how current that is. The whole lot is 300mb, so better off to stick it on a CD for you. PS... was it you or James that wanted the 300 mounts off of my (weebles) chassis? i'm just about to fire up the plasma cutter... ![]() ![]() |
https://files.me.com/daniele.gardellin/mqc10j But MY2011 have Bosch ABS ECU (not more WABCO) and I do not know if the related part of diagram is changed.... NEed to upgrade my database ![]() ![]() ![]() ![]() IID Pro MV License |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Thanks Jamie
Was looking for an alternative speed pulse input, bar for the one behind the clocks,, !! Fitting the cruise kit, you need a VSS, and the normal way is Red/Black behind the clocks,, however on 11MY it would seam the signal is not strong enough ?? so had to go back to the speedo drive on the gearbox,, that cured it ![]() A CD would be good thought ![]() ![]() Diesel mounts ,,, Me ![]() ![]() ![]() Main Brian James Trailer Dealer for South West UK |
As the speed transducer on the transfer box uses the 3 pin plug (Same as the rear lights...brake & side) it would be a doddle to make up a loom with a male and female plug each end, and a splice in the middle to take the speed signal off.
shout if you need a hand. I'll burn the disc and wang it in the post. got your address here somewhere. yup... it'll be James and the TGV that needs the godly engine mounts. ![]() |
Thanks dgardel
You posted as i was typing !!! Yep, their are differences,, which is why my cruise control, has taken a while to get up and working as it should Now all sorted ![]() Main Brian James Trailer Dealer for South West UK |
