![]() | Home > Puma (Tdci) > 2.4 Puma on losing streak HELP |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
If you had the box out, check the earths on the transfer box. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
And I've read the relays under the seat can come loose causing random dash lighting. Ray
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
what he said look for a dodgy earth cable DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
^^^^ This is exactly what I had once. WeWillWin🇬🇧🇺🇸
i had one ring terminal that had broke the ring off of the terminal body,
It was only the insulation that held it together. ABS light on, TC randomly flickered Tail lights not working Occasional symptoms of a flat battery. Heated Windows not working. All of these would happen at random times, and in damp conditions it got worse, I only found this after checking with a multimeter, Visual inspection wasn't good enough. Hope you get it sorted, I know how frustrating these problems can be, I think most of us on here have had a visit from the "Lucas gremlin" at one time or another ![]() Wanted, Forward Control Anything considered. |
Mine was dirty and loose, but you'd never notice to look at. WeWillWin🇬🇧🇺🇸
Mack Member Since: 11 Jan 2014 Location: Central America Posts: 58 ![]() ![]() |
Hello mates thank you all for your replies. Both of the earth cables that go to the transmission were not even bolted on. After screwing them in place, the rig feels like new again 😁, what a headache for such a simple thing. Thanks again to you all, this forum is really helpful!
Cheers Mack |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I love reading these threads
![]() When you're back rolling with just one little fix, no more worries and time for a beer. ![]() |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2536 ![]() ![]() ![]() |
Glad you are sorted with such a simple fix. It's nice to hear that the Defender 130 is the only vehicle for your work.
![]() Mini Countryman Cooper S Morgan Plus 8 |
