![]() | Home > Maintenance & Modifications > 2.8 iveco engine |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 406 ![]() ![]() ![]() |
Just been scrolling through eBay and noticed someone selling a Santana ps10 engine and box adapter
https://m.ebay.co.uk/itm/Landrover-engine-...SwYVlZ~LZi Has anyone done this conversion ? Seams like it could be a cheap worth while conversion. I've had a few iveco through out my time and they have been very good engines. I think in a old 90 it would be lovely |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Why when you could fit the transit diesel, just curious?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
Frank Elson LR mag journalist used to run 2.8
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The TDDI was a pig, so many catastropic failures on those, and they were gutless compared to the TDCI version. By the time they got to the TDCI they'd been and sorted out most of the other faults with the engine too. There was a lot more development done on them beyond the fuel system. Much like a 2.2 is very different to to a 2.4.
The old Transit Di version of York engines were pretty bomb proof mind you, but noisy and rough by modern standards. The 2.8 Iveco is a good lump, but it's probably easier to fit a 3.2 Puma engine if you're fitting to an existing Puma vehicle. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
The way the UK is going with diesels, I wouldn't be swapping any diesel engine in! I've put plans to tune my td5 on hold until I decide if long term a petrol swap may be a better choice
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
I worked for an Iveco dealer for 13 years and did my apprenticeship when the 2.8 (8140 engine) was fitted to Daily vans.
They where a dependable unit and ran for many miles with no trouble as long as servicing was kept up. But they were last produced in 2004/5, only 8 valve (albeit had lots of bottom end torque) so no were near as refined as a puma engine. If i had a Tdi i would consider this as an option as in my view it is a better engine than a Tdi, but has electronics (unless you get the earlier 106hp variant with rotary fuel pump) and being early common rail injectors have been known to cause non start issues. Overall they was a dependable engine to Iveco/Fiat like the Tdi was for Land Rover. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88β 2A 200tdi 2002 110 Hardtop |
I've only ever had one failed puma and it was a 2.2 2009 170k engine the cam carrier snapped, I've had a ![]() |
They were forever blowing coolant hoses in our fleet and we had several with piston failures. awful rough old things, the older York based lumps were rough but at least they were robust.
Apart from the EGR the electronics on the TDCI pumas are very reliable. Even the bits that do fail, like the VCV and EGR, fail mechanically rather then electronically. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
I was going to say but it has already mentioned that probably a 3.2 TDCI would be a better option. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
I think someone did a 2.8 version of the 300TDI, i forget what it was called.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
called TGV if I remember correctly
It would be a better option no dout however i was basing the swap on a landrover 90 where the comon swap is a 300tdi/200tdi |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
I really don't see any reason why it shouldn't work out to be a good transplant providing the engine you buy is in good repair.
These engines have a reasonable enough reputation in the Santana and at the time of their launch in the Santana were considered superior to the Tdi. Old transit engines belong in old Transits, as do modern Transit engines, come to think of it 😆😉 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
vito115 Member Since: 29 Aug 2012 Location: kent Posts: 29 ![]() |
i was going to fit one in a defender years ago, i remember going to Billing and speaking to frogs island as they were fitting the 2.5 iveco engine but when i said i was after the adapter plate etc the guy became very cagey and wouldn't say where they were getting them from, i think it was an iveco dealer in Southampton ? Anyway cut a long story short the Landy got nicked & i flogged the engine !
