Home > Technical > 2009 2.4 TDCI Defender Starting Issue (10AS? IPAC? ECU?) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
Check the IPAC electrical plug at the rear is secure which would be a good starting point, as well as all your main Earth straps.
Plus both battery post clamps. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Nov 2017 7:27pm |
olliecracker Member Since: 18 Nov 2017 Location: Gloucestershire Posts: 19 |
Also.... No fault Codes found with the LYNX Diagnostics
I'll check them again tomorrow!, Looking at the connector on the back of the IPAC, all looked well. Will try checking continuity though!
18th Nov 2017 7:29pm |
Hi Steve,
From checking all the earths I could find, The IPAC plug and testing continuity between them, I can't see any problems. I'm starting to look a the 10AS module but internally it looks fine, no damp whatsoever! Do you know if the 10as would stop the Defender from cranking or if it just sends the immobilization signal to the ECU to stop it from starting? Because if it does stop the engine from cranking, then maybe I can disregard this as part of my problem! Thanks, Ollie |
20th Nov 2017 4:11pm |
in your case ECM sends crank enable will LYNX diagnostic tool not give you live dater when try to start the engine i.e. crank enable output
20th Nov 2017 7:31pm |
Hi,
I've just plugged it in and it says starter.mot.enab and then says OFF. Even when the engine is turning over, the LYNX Tool Still says that it is Off. Very confused. Does this mean that the 10as Immobiliser isn't working? Thanks, Ollie (Also... Just been reading up about the Nanocom and put it on Credit card |
20th Nov 2017 8:49pm |
Click image to enlarge Here's a screenshot! |
20th Nov 2017 8:55pm |
i no this bit of side step can see crank pos read out on start
http://www.defender2.net/forum/topic48321....ank+sensor |
20th Nov 2017 9:14pm |
Click image to enlarge Cam/crank sync okay? This was when I was cranking the Landy over! |
20th Nov 2017 9:25pm |
Could the crank position sensor need replacing in its self.
I thought someone did have that issue on here at one time. Also worth trying.. press unlock on the fob right before starting and see what difference there is if any. Is the red alarm light off, and appears to be functioning as you'd expect? It should not flash at all once unlocked and before you start. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
20th Nov 2017 9:27pm |
By the looks, The sensor is changing state
20th Nov 2017 9:28pm |
you should be read RPM
20th Nov 2017 9:32pm |
I don't have any Fob, nor have I ever had the immobilizer light up on my dash. Its constantly been off for the year and a half of owning the landy.
I can see the sensor changing state which makes me look away from that. but by the looks it is a cheapish part to replace Lynx Diagnostics says the passive immobiliser is enabled.. even though I have never had a key fob |
I'll look again!
20th Nov 2017 9:33pm |
