Home > Puma (Tdci) > sound proofing 110 roof and bonnet
Stacey007
Hello
I've used silent coat and closed cell on the truck rear boot, rear seats, seat boxes and driver / passenger footwells also the front doors and box's
I think the biggest improvement was the seat box?
Anyway I have left the roof as taking the headlining off concerns me, and also nothing under bonnet?
Are these two other areas worth doing?
Thanks
Post #665784 20th Nov 2017 4:22pm
mk1collector
The roof if done well will make a big difference, as for the bonnet, sound deadening doesn't stop noise so it won't cut down engine noise only resonance from the bonnet itself. Ray
My build thread
Post #665789 20th Nov 2017 4:30pm
bankz5152
Headlining removal seems like an enormous task but its actually quite straight forward and simple. Just buy some more of the "tree" fixtures as you'll no doubt break/damage a few.
I used Fatmat (Dynamat alternative, just as good, half the price) and acoustic eggshell foam usually used in studios and and the like for the roof. Stuck the foam down with high temp spray adhesive. Made quite a big difference
I wasn't concerned with the foam soaking up water as my roof was totally water tight, though I did run some silicone over any joints first.
Post #665791 20th Nov 2017 4:36pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I used this on the underside of the bonnet and very pleased with it. Was considering doing the roof in the hard top as well, as the finish looks neat enough...
https://www.dodomat.com/collections/thermo...stic-liner
Post #665797 20th Nov 2017 5:15pm
