Home > Maintenance & Modifications > Axle HARMONIC dampers etc
LR90XS2011
Looking at discovery 1s and 2s land rover did a few things to help remove road noise, 1 thing discuss on here is spring isolator and another appears to be the rotoflex coupling on the rear diff but has anyone tried the harmonc dampers?
could this help those trying to remove road noise
FTC1499 DEFENDER 90 TDCI XS,
Post #664662 15th Nov 2017 9:14pm
They're not designed to remove road noise. They're supposed to counter vibrations in the drive train when running over rough surfaces and are part of a package designed to improve NVH.
It wouldn't do any harm to fit them to a Defender but can't imagine them making any significant difference as the vehicle structure is so different. Darren
Post #664664 15th Nov 2017 9:22pm
zsd-puma
On a disco where they have a fair amount more sound insulation, you would hear vibrations and odd droning noises that you can't hear in a Defender because they're drowned out by everything else. So fitting them on a Defender probably woudn't make any noticable difference unless you've gone to the trouble of building it properly and sound proofing and sealing it up properly.
Post #664692 15th Nov 2017 10:37pm
