![]() | Home > Puma (Tdci) > Puma not turning off! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Possibly dodgy main Earth straps. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
I had this once and it was a dodgey accessory plugged into the 12V lighter socket. Remove and isolate said socket.
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 ![]() ![]() ![]() |
Thanks guys for the answers so far. I'll pass them on and he can give it a go.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
defiantly a dodgy earth. I had a vauxhall years ago that would run as long as I had my foot on the brake. It was caused after changing a rear brake light. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
did he change the rear lights bulb with led ones?
and do the car kill the engine when pushed the brake with the key off? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Yes he did change the back lights. Not sure if the brake pedal will kill the engine. I'll get him to try that. Is there a fix, if that is the case?
Many thanks for the info guys. Jon Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
First re-install the original bulbs, second try another type of LED bulbs.
On my car was happen the same "strage" effect, after that I installed JW Speaker round rear LED lights. Also the Wipac kit are good Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I'll suggest that to him dgardel. Thank you.
any feedback? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
I'll be seeing him tomorrow, and will be sure to let you know the outcome. 👍
