Home > Puma (Tdci) > Puma not turning off!
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Asking for a friend....
He has a 2008 Puma and the engine is continuing to run even when he removes the key from the ignition. Turning the ignition off kills the heater blower and stereo, the the engine keeps running. He also discovered that with everything off, if he switches on his side lights, the ignition comes on (fuel gauge, temp gauge etc) !
He recently fitted led lights all round (including headlights) but no other recent electrical work other than that.
Any advice would be gratefully received.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #663233 10th Nov 2017 7:53pm
Possibly dodgy main Earth straps. No Guts, No Glory.
Post #663235 10th Nov 2017 7:57pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
I had this once and it was a dodgey accessory plugged into the 12V lighter socket. Remove and isolate said socket.
Post #663320 11th Nov 2017 2:30am
DefenderJon
Thanks guys for the answers so far. I'll pass them on and he can give it a go.
Post #663340 11th Nov 2017 7:47am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
defiantly a dodgy earth. I had a vauxhall years ago that would run as long as I had my foot on the brake. It was caused after changing a rear brake light. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #663343 11th Nov 2017 7:53am
dgardel
Italy
did he change the rear lights bulb with led ones?
and do the car kill the engine when pushed the brake with the key off? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #663749 12th Nov 2017 5:23pm
DefenderJon
Yes he did change the back lights. Not sure if the brake pedal will kill the engine. I'll get him to try that. Is there a fix, if that is the case?
Many thanks for the info guys.
Jon Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #663756 12th Nov 2017 5:49pm
dgardel
Italy
First re-install the original bulbs, second try another type of LED bulbs.
On my car was happen the same "strage" effect, after that I installed JW Speaker round rear LED lights.
Also the Wipac kit are good Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #663758 12th Nov 2017 5:55pm
DefenderJon
I'll suggest that to him dgardel. Thank you.
Post #663759 12th Nov 2017 6:02pm
dgardel
Italy
any feedback? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #664088 13th Nov 2017 9:50pm
DefenderJon
I'll be seeing him tomorrow, and will be sure to let you know the outcome. 👍
Post #664096 13th Nov 2017 10:16pm
