![]() | Home > Series Land Rovers > Latest purchase - Series 3 109 (Alfred the 109) |
orkneydave Member Since: 25 Sep 2016 Location: Orkney Islands Posts: 76 ![]() ![]() |
Alfred is currently in my local garage at the moment having all the jobs dont that I sadly haven't had time to do but it seems to have been one problem adter another.
Current issue is that the ball joints that are on the new track rod and drag link I supplied from Paddocks are too small! Anyone heard of this before? The ball joints are threaded into the rods okay but the bottom tapers are too small apparently. I've called Paddocks and they are confused too as they say they should be the same size. I'm guessing I have a series 3 axle but wouldn't have thought it would make much difference anyway! Any ideas much appreciated. Cheers, Dave |
The sat nav is a Garmin LMT51. It uses a specific wireless camera from Garmin (a BC30 I think). Works really well and I have found I rely on it more than I thought now.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Dave,
I have never heard about the track rod ends fitting poorly either? Over the last few years I've had 4 complete sets for various Series Land Rovers, And all have been spot on. I must say one thing, I've been sent/ordered quite a few Bearmach parts recently, And the quality is somewhat disappointing! It is a brand I've always tried to avoid if possible, The Britpart parts seem to be quite good recently, maybe they have finally got their act together? I had a pair of Bearmach vent flap seals for my series 3, which I've just sent back today! 2" too short, and they just consisted of a piece of badly cut foam like you would stick around a drafty window at home, They were nothing like the originals ![]() Hope you get it all sorted soon! Cheers 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Firstly, apologies for not posting here in a while, I will post an update shortly!
Anyway, coming home the other day (new years day actually) Alfred decided to vibrate violently before I brought him to a stop. I checked all the wheels were still on (I've had a wheel fly off when driving my son's defender) and that everything was in order. When I set off to limp home, all seemed okay and he drove fine. At the time I thought it must have been something to do with disengaging 4wd earlier in the day. The roads had been very icy the day before so I have been in 4wd, but before setting out on new years day, I disengaged it by pulling the red lever back and forward. I assumed that 4wd hadn't actually disengaged until the event with the wobble and that it had popped out at speed, causing the wobble. Anyway, all seemed fine until this evening when again a sudden violent wobble occurred. I noticed that the steering felt a touch lighter before hand but put this down to it being very windy and the steering box possibly requiring a slight tighten up. Again, I pulled over, checked all was where it should be and set off with no adverse effects. I should mention that bot times I have been doing around 30mph (possibly slightly less). Alfred had a service at the end of November with new track rod, drag link, wheel bearings, rear shock and swivel kits (and swivels) fitted. So, any ideas? I have a drive south in a couple of weeks (Aberdeen to Edinburgh, then back up to catch the ferry home from Scrabster) so keen to resolve before then! |
Incorrect swivel preloads is the first thing that comes to mind, particularly give the work you've had done. Darren
Death wobble was down to a loose track rod
![]() Anyway, time for a long overdue update on what I've done so far: Wire up reverse light Following on from fitting the reversing camera previously, I still had to wire up the reverse light and gearbox switch! This was surprisingly easier to do than I expected. Floor up ![]() Click image to enlarge Hole in selector re-tapped and switch fitted ![]() Click image to enlarge ![]() Click image to enlarge and wires connected ![]() Click image to enlarge Fitted interior light This was a £3.99 find at a filling station whilst on my travels south. I plan on wiring in a more permanent solution at some point but this works well for now! I covered it in black insulating tape to help it blend in a bit! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge New hood When bought, Alfred came with a rather old but reasonably watertight FFR tilt. Whilst it kept me mostly dry, I wanted to improve how Alfred looked, have the ability to roll up the sides and have side windows. After a bit of research I opted for a new hood from Undercover Covers (despite the rubbish website!). After a wait of around 6 weeks, the new hood arrived and was fitted. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Christmas tree duties ![]() ![]() Click image to enlarge Rescued my son when he got stuck in his Defender ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Fitted new tailgate hinges Having seen these on Conrad's brilliant thread for his V8 90 I decided to get a set of two-way tailgate hinges from Purely Metal. I had to wait a bit as he had no galvanised ones in stock but it was orth the wait. The kit: ![]() Click image to enlarge It was fairly simple to fit and has made the back of Alfred so much easier to use and get in and out of. Would highly recommend this! ![]() Click image to enlarge ![]() Click image to enlarge Fitted new door handles I got a bit fed up of my passenger door flying open randomly and didn't think usung dog leads to secure it was going to be a long term solution ![]() Click image to enlarge I also found cracks in the driver's side mechanism ![]() Click image to enlarge So I ordered some anti-burst door locks from SP4X4. I got the kit that included all the bits required including a step drill bit (I already have a set but have found the one supplied useful for drilling out rounded off screws etc!) ![]() Click image to enlarge ![]() Click image to enlarge Oddly, one of the strikers seemed to have been previously opened and had mis-matched screws holding the rubber block ![]() ![]() Click image to enlarge Anyway, old handles off ![]() Click image to enlarge and new ones fitted ![]() Click image to enlarge Much better now but still require a bit of fettling. The driver's door works fine although the handle is a little stiff, however the passenger door first proved almost impossible to open. I have adjusted it a fair bit but now the door doesn't close as tight as I would like. I think the doors themselves may need adjusting at the hinges so plan to tackle this on a sunny weekend sometime. Swapped cord on tailgate flap for bungee I'd been meaning to do this since fitting the new hood at the end of September but wanted to wait until the hood had been through a few wet/dry/hot/cold cycles so as to reduce the chances of shrinkage. Anyway, this was a fairly easy job. I ordered a 2m length of bungee from Amazon and found an online chandlrey that could supply crimps to allow me to create eyelets at either end. I put the first eyelet in before threading the bungee though the flap and fitting the eyelet on the other end. I used heat shrink to seal over the crimps and hopefully protect a bit from the salty air here. Along with the new tail gate hinges, this has made a massive difference to getting acces into the back of Alfred. ![]() Click image to enlarge ![]() Click image to enlarge Moved my son's kayak ![]() Click image to enlarge Drove through the Highlands in the snow ![]() Click image to enlarge Fitted Grafty's most excellent lower dash vents Not much to say about these other than that I am really pleased with them (there's lots more here http://www.defender2.net/forum/topic59006.html) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Soundproof ![]() As Alfred is my daily driver and I spend at least an hour a day at the helm I was a little concerned about the effect on my hearing. I ordered 2 boxes of 3mm Silent Coat from deadening.co.uk and a 2m roll of 6mm ribbed rubber mat from Amazon (actually from a seller in Bristol and significanlty cheaper than any Land Rover parts supplier). Obviously I picked the coldest day of the year to fit ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I have left the upright surfaces for now as I want to retain a little originality and patina in the back. I have lined the inside of the tool box and need to re-fit the catch pin. Rubber matting was cut to fit and laid before re-fitting the seats ![]() Click image to enlarge and most importantly rug back down ![]() Click image to enlarge I still have 1 box and 1 whole sheet of Silent Coat left over but I plan to apply this to the cab area shortly. I already have a Wright Off-Road cab mat fitted but hope that the Silent Coat will improve things further. With this fitted in the back I think i have lost about 6db when driving at 55mph (according to my phone anyway) but can have the radio turned down a bit lowe and can hear it all the time now. I still need to fit a rear seal and retaining strip on the floor at the back (the old one crumbled away a while ago). Roll up the sides Having had the new hood for 6 months I finally managed to get the sides rolled up yesterday before heading home from work! ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Sides rolled up again today but no pictures yet! Still to do: -Continue to improve the steering -Fit soundproofing in the cab area -Fit MPH speedo, spare instrument dial (still to be refurbished) and new instrument panel -Source and fit new lower dash (found mine is rather tender when fitting the vents) -Adjust the doors (or even replace them). I also plan to make door cards. -Wire up a front pair of speakers so that I can use my bluetooth hands free (aparrently doesnt work through the rear speakers but there has been little point with no soundproofing) Apologies for the long post. Hopefully I won't leave it so long before updating again! |
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 ![]() |
What a brilliant post, really enjoyed the photos.
Cheers ![]() Defender 90 D200 |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Great post OD, like you I have the Purely Metal hinges on the tailgate of my V8 90, they make the back a bit more versatile and easier to clamber in and out when in sideways opening mode.
That is fantastic. I love your dog guard
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
Love the update OD
Thanks for the kind comments!! Hopefully I'll keep this thread updated more often than recently!
The guard is actually the base of the crib that my wife slept in as a baby! The rest of it was in poor shape after being in the garage attic for years so was going to the dump when I realised the base was the perfect size and shape to use as a dog guard to stop our springer leaping onto my lap!
Sometimes, but he has to fight for space with my MGB GT which is in bits and my Outlander PHEV when it's charging! |
Thanks for the reply
