Home > Maintenance & Modifications > Rear arch spare fuel tank.
Page 2 of 2 <12
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Sorry.....I meant to say Big Country.... Sad
Here is the link to their site. I'm verry happy with my tank!
http://www.bigcountry4x4.com/Products.aspx?ProductTypeID=13
Can try to post pics if anyone wants?
Post #66107 4th Apr 2011 8:17am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Marius wrote:
Might not be of help. I have the Big Countryone here is South Africa. The guy pointed out the differences between Big Country and Frontrunner. Frontrunner is 45l and thus it's too far out (Too much volume). Rubbing happens on the wheels. His tank is 40 l but also the side exposed is arched, not straight. My 2CW.
Hi.
Do you know what tyres he is runing? Puma 110 SW
90 V8 SOFT TOP
Post #66108 4th Apr 2011 8:18am
LESVOSD110
Thanks for link.Please post some pics if you can.
Thanks Puma 110 SW
90 V8 SOFT TOP
Post #66110 4th Apr 2011 8:22am
LESVOSD110
To fit one of these tanks to puma with plastic main,do you have to drill a hole for what is called a balance pipe.From what I have read,on metal tanks (TD5) you use the drain plug.
I'm not keen to make a hole in my main tank. Neutral Puma 110 SW
90 V8 SOFT TOP
Post #66236 5th Apr 2011 6:44am
Marius
How do I upload fotos of this tank?
Post #66266 5th Apr 2011 12:16pm
mse
Upload to your gallery (next to the defender 2) then use the path provided Mike
Post #66268 5th Apr 2011 12:31pm
Marius
Hopefully this does it:
Post #66272 5th Apr 2011 12:42pm
mse
simples Thumbs Up Mike
Post #66273 5th Apr 2011 12:55pm
LESVOSD110
mse wrote:
simples Thumbs Up
Thanks Marius.
Did you have drill your main tank to fit a balance pipe? Puma 110 SW
90 V8 SOFT TOP
Post #66285 5th Apr 2011 3:12pm
Marius
No, I had the tank fitted so I'm not sure what they did unfortuanately...
Post #66337 6th Apr 2011 6:31am
landy andy
I have not had one fitted, but belive that no holes are drilled into your tank, they connect it via the breather pipe on your old tank.
Andy
Post #66339 6th Apr 2011 7:11am
LESVOSD110
Andy
They do connect via breather for vapour breathing,but for the tank to empty,there is a balance pipe.On the older steel TD5 tanks they linked via the drain plug.I do not know if ther is a change on the plastis tank. Confused Puma 110 SW
90 V8 SOFT TOP
Post #66365 6th Apr 2011 12:48pm
Page 2 of 2 <12
