![]() | Home > Puma (Tdci) > Wiper Park Switch Problem (And How To Fix) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
Excellent info thanks for sharing
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Martin, can you pin this please NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
I did notice that there was a little prior warning when the park switch went on mine recently, I had a couple of "hesitations" when the wipers were working as if the power supply was interrupted when working. Another thing was that I have one of those "99" programmable intermitant wiper relays and it was becoming harder to set, sometimes I couldn't alter away from the default. This became apparent four or five days before it packed up, I use mine as a daily driver and I thought it was the relay starting to fail but after replacing the park switch, all is back to normal.
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Thank you
Fabio |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
Got this job to do tomorrow, fingers crossed will go ok ! @steve_overland on Insta.
110 expedition vehicle with pop roof |
Steve, let us know how it went i'm doing it next weekend.
Fabio |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 ![]() ![]() ![]() |
Great write up because this costs £520 at a Land Rover dealer.
I know this because I had exactly this problem when I picked up my, new to me, 2010 vehicle. They fixed it for me and presented me with said £520 invoice. I politely and quietly told them what to do with it. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17717 ![]() ![]() ![]() |
I posted a detailed "how to" on this very subject in 2011, in this thread:
https://www.defender2.net/forum/post68216.html (Ninth post down). ![]() |
Thank you Snorkers and Blackwolf.
I did this on Sunday and it worked a treat. Whilst doing this the battery also failed... ![]() Thank you Gents. Fabio |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
Thanks Snorkers and Blackwolf.....job done in 45 mins (but my Step Son did help me, he works on the line at JLR, so a bit more confident then me}!!!
Happy New Year all Rob |
Went super easy the second time, the first time I stupidly bought a cheap copy and it fell apart fitting it..... @steve_overland on Insta. 110 expedition vehicle with pop roof |
I did mine last week and it was pretty simple, once you know what you are doing.
Mine took at least 2 hours to change but the write up is correct. Fabio |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
I'm just about to do mine for the 3rd time (the new lucas switch I got, I managed to muller the plastic moulding of the switch so the C shaped spring clip wouldn't hold it in position... even with cable ties around it. So refitted the old switch.
New one (2nd) arrived yesterday so I'll get around to fitting it sometime (Td5 not puma) |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 282 ![]() ![]() ![]() |
Word of warning, when I did mine I somehow managed to detached the metal clip removing the old switch that holds the switch to the side of the motor which then ended up inside the motor.
What I did find was I managed to remove the motor completely with the dash board only pulled forward by using a crows foot spanner that fitted on the end of a socket set extended bar to undo the drive cable. fiddly but doable. ![]() Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
