![]() | Home > Puma (Tdci) > Wiper Park Switch Problem (And How To Fix) |
Timster Member Since: 11 Feb 2020 Location: Herts Posts: 10 ![]() ![]() ![]() |
Has anyone any tips for replacing the park switch when there is all the Air Con gubbins fitted ? (XS model).
Thanks |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
I don't think that aircon makes any difference.
All the blowers etc hang underneath the passenger footwell. Directly below the wiper motor (I think)
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
So my wipers have gone mad again.
![]() Last year I changed the wiper park switch, now they don't stop unless I switch the engine off. I have bought another wiper park switch but i'm a bit worried that it might be the relay. Does anyone have any ideas. Thank you Fabio |
It is more likely to be the park switch, but the relay is easier to change to try.
You need to buy a second Defender so that you have one to try swapping parts with! ![]() |
I think you are right ![]() But as I have the park switch at home I'll try that first. Thank you Blackwolf. Fabio |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 ![]() ![]() ![]() |
It wasn't a job i had been looking forward to but today I replaced my wiper park motor switch on my 2011 110SW. I needn't have been anxious. By following the detailed advice it all went very smoothly. Problem nicely sorted in no time at all. Thank you to the contributors who have kindly taken the time and effort to share their experience and knowledge.
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 213 ![]() ![]() ![]() |
Thanks for the write up Snorkers, carried out the park switch replacement with the minimum of fuss. The hardest part was putting the grab handle back on as the captive nuts are off centre.
![]() Click image to enlarge The 3 spade connectors orientation for reference. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
