Home > Puma (Tdci) > 2.2 vs 2.4 running temperature
Cheshire110
Hey guys,
Anyone run an ultragauge/scangauge and noted the running temp (coolant) of their 2.2?
Mine sits at around 92-96 degrees on the motorway, around 90 on slower roads. Bit warmer than my 2.4 was and bit warmer than i’d have expected. Been like that since new though, never overheater or anything and never hit 100 even.
Anyone else notice similar temps? I was under the impression most cars ran at 80-85 degrees. Cheers, David
Post #661551 2nd Nov 2017 11:31pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
2.2. Highest 96, lowest 90.
Post #661562 3rd Nov 2017 12:09am
ericvv
David, 85°C running temps are a long time ago now. Manufacturers have increased that, mainly for emission control reasons, not really because it is better for the engine though. I personally doubt that coolant temps in the mid 90's are better for an engine than if they were in the mid 80's, rather the opposite I think. And if you would have coolant temps under normal conditions in the mid 80's, it surely gives the entire coolant system more margin to keep it all in check in case of any type of engine stress situations (very hot outside temps, heavy load on engine, etc.) where coolant temps would naturally go higher. I'd rather have a coolant system which fully opens to its max capacity already already well under 90°C, than only at something close to 100°C....
One of the answers to this is the PEL500110. It has been discussed at length in below thread, and many have installed it, never heard any negative feedback later. Top of my head, the standard Puma thermostat (cream colour) starts to open only at 88°C and is fully open at about 96°C, while the PEL500110 thermostat (grey colour and the original thermostat on the D2) starts opening at 82°C and is fully open already at 88°C. This PEL500110 works for both 2.4 and 2.2 engines.
Happy reading, it really is worth the 9 pages. You can then make up your own mind.
Eric
http://www.defender2.net/forum/topic32086....=pel500110
http://www.defender2.net/forum/topic56597....=pel500110 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #661571 3rd Nov 2017 5:49am
pannawonica
Australia
82degree thermostat will help, however the temperature will still exceed 82C when loaded up and pulling a grade at @50C. I think that the radiator is a little inadequate in capacity! Thumbs Up
Post #661765 4th Nov 2017 5:40am
ericvv
^^ I think something would really be wrong with your motor if "when loaded up and pulling a grade at 50°C" outside temps your coolant would not exceed 82°C. Laughing
Now, those 50°C outside temps..........., when was the last time we had those here again?
Post #661773 4th Nov 2017 8:08am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
My 2.2 runs between 93 and 97 on fast roads. Occasionally hits 99/100 on hill with trailer so I think yours is fine.
About 18m ago it was running a bit higher but a new thermostat (cream) sorted that.
Since fitting the ultragauge I do find when towing using 5th rather than 6th gear on A roads keeps it cooler
Post #661774 4th Nov 2017 8:13am
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
Hi David,
I found the same when I changed my 2.4 Defender for a 2.2. I found there was a slight increase in running temperature when running over the same roads when using the 2.2.
My local Ford dealer put a slightly thicker coolant mix (my diagnosis as it seemed "thick") into my Transit after a hose replacement which increased the running temperature in my 2.4 Transit van by 5 degrees Celsius. As I was not happy with the service I was receiving I changed dealers and asked them to drain and refill the coolant system with the correct mix. Problem solved and now runs correctly.
Post #662134 6th Nov 2017 7:11am
My 2.4 ran a bit hotter with coolant concentrate and water mix that was shoved in. Rolling Eyes
Since I've ran pre mix, it's ran a degree or two cooler at an estimate. Across the board. TheThunderRolls🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #662170 6th Nov 2017 11:53am
Cheshire110
Thanks for the advice as always guys Thumbs Up
Nothing to worry about then, just a difference Cheers, David
Post #662205 6th Nov 2017 2:08pm
