Home > Wheels & Tyres > Tyre rotation
Page 2 of 3 <123>
Grouse
I usually swop front to rear without swopping left to right so that the tyres are still rotating the same way. This evens up the wear as I always find that the fronts wear quicker and also on the shoulders
Post #661914 4th Nov 2017 10:46pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Roddy plus one. for every vehicle I've ever owned and ever will (until I finally get my hands on a 993) other than that I don't buy five new 'uns, just the four and keep the best of the oldies as a spare.
The only argument against rotation is uneven wear across the tread blah blah blah, but if you notice that you should in any case identify the cause and correct it.
Peter
Post #661973 5th Nov 2017 12:42pm
Not the case with mud tyres. These will always wear unevenly if used on the road and must be rotated so that the direction is reversed if you want to even up wear.
Post #661975 5th Nov 2017 1:03pm
ibexman
You have all got too much time on your hands 🙄🙄
Post #661976 5th Nov 2017 1:06pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
The conditions you drive in have a huge influence in this. I tend to rotate and balance every 10 000 km I then rotate balance and align every 20 000km. Where I drive the tyres are subject to varied road conditions potholes, gravel / off-road. The vehicle will be subject to various load conditions etc. The posters here that think tyre rotation is not really necessary probably do not drive in the sort of conditions I face. In my situation careful monitoring of tyre pressure, rotation and balancing can double tyre life!
Post #661977 5th Nov 2017 1:15pm
Gonarezhou
RoddyK05 wrote:
I do mine yearly or every 6k miles in this fashion. I’d rather spend the money on 5 new tyres than have 4 new ones and an old unused spare.
Yes this is correct Thumbs Up Thumbs Up Thumbs Up
Post #661979 5th Nov 2017 1:21pm
ibexman
I don't have the time to worry about tyre rotation there are more important thins to deal with
I think its really sad 😭
Post #661981 5th Nov 2017 1:57pm
Screbble
I mentioned this thread to my wife....
She simply responded by telling me that the tyres rotate themselves when you are moving Confused
It wasn't worth continuing with the conversation Whistle
Post #662068 5th Nov 2017 8:55pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Yes I do my D3 and the wife’s Defender the same, every 6000 miles. Thumbs Up
Post #662072 5th Nov 2017 9:10pm
Gonarezhou
Big Cry
Big Cry Rolling with laughter Rolling with laughter
Post #662125 5th Nov 2017 11:25pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I'm sure that I read on a Land Rover service sheet "Do not rotate wheels and tyres" and I think it's in the hand book as well.
The advice I was given from the Independent I use and the tyre place was to swap front and rears, near side front to near side rear and the same for off side to even the wear as the front tend to wear the edges due to the steering effect. This effect is even more pronounced if towing. The tyre place charge £5.00 for the whole job and the Indy do it for me on services as they have the wheels off any way. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #662156 6th Nov 2017 9:17am
Birdy
I don't have the time to worry about tyre rotation there are more important thins to deal with I think its really sad 😭
I agree, tyre care and inspection is MUCH less important than things like Nakatanenga bling and whether or not my LED interior lamps match the ones on my bumper...
Peter
Post #662266 6th Nov 2017 6:23pm
WilkoW
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
So, I’m a bit thick and have just followed this method but cannot work out why this particular method is better than just swapping front to back; other than utilising the spare?
Roody’s method as above...
Post #758994 16th Feb 2019 2:44pm
If you swap front to back and side to side, each tyre has it's direction reversed, which helps to even out the wear. Including the spare in the mix is just to use the spare. Otherwise, you end up with four worn tyres and one brand new but old one. Darren
Post #759012 16th Feb 2019 4:21pm
miker
I do front left to back right and front right to back left.
Keeps the wear even, the fronts do wear faster. Then when I come to replace them I can replace a whole, evenly worn, set!
On all my 2wd cars I just replace the fronts, put the backs on the front and the new ones on the back.
Post #759060 16th Feb 2019 7:14pm
Page 2 of 3 <123>
