Home > Td5 > Need a louder indicator warning..
Gareth
My wife loves driving our Defender, but complains she can't always see the direction indicator warning lights on the dash, because the steering wheel partially obscures them. She is not the tallest person, and she says that she is always leaving the indicator on, as the self cancel is not always that good.
Does the TD5 use a traditional flasher unit, like my Series 2? If so I know I can wire in a simple buzzer. Or does anyone else have another solution? Rather than a buzzer, just something that makes a louder click would be OK.
Any suggestions? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #661945 5th Nov 2017 8:35am
How about a booster seat? Whistle Darren
Post #661950 5th Nov 2017 9:04am
Swine&Small
New, Taller wife Whistle 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #661955 5th Nov 2017 9:32am
rallysteve
Yeah TD5 uses a traditional flasher unit. You can wire a buzzer quite easily using a couple of diodes (one from each indicator circuit to the buzzer then to earth). Easy to pick up the two wires needed at the warning lights on the dash binnacle which would be a good place for a buzzer.
Post #661961 5th Nov 2017 10:17am
Gareth
Cheers, is the flasher unit behind the binnacle? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #661971 5th Nov 2017 12:24pm
Gareth
Booster seat! She already has a cushion to sit on, but complains it's not heated like the seats, and I can't afford a taller wife. Wink 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #661972 5th Nov 2017 12:26pm
rallysteve
Yes flasher unit is behind the binnacle. You need to pick up the wires after the stalk though or the buzzer is unlikely to work properly.
Post #661978 5th Nov 2017 1:16pm
Rashers
Have you ever considered moving to Norfolk?
A lot of people round here don't consider indicators to be important and never use them Rolling with laughter
Post #661988 5th Nov 2017 2:56pm
Swine&Small
Or never turn them off. Indicating right and then going left whilst on the phone is a county sport.
Arrow Sheep Sheep Sheep Sheep Sheep 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #661993 5th Nov 2017 3:22pm
Rashers
Thumbs Up
Post #661996 5th Nov 2017 3:52pm
geobloke
May help. When I swapped to LED indicators the replacement adjustable relay (Hella knob on top to adjust the speed of the flash) is much much louder than the original LR item.
But if you want a louder buzz, a bit like on a HGV or Bus then;
https://www.ebay.co.uk/itm/CAR-INDICATOR-W...l4275[url]
Post #662041 5th Nov 2017 7:29pm
CarMan
Can you remember if the adjustable flasher relay for use with LED's is the Wipac branded item, as mine is and is much quieter than my OEM relay and I would like it to be louder, so I am hoping it might be the Bolt-On-Bits one? In which case I will get one Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #678404 14th Jan 2018 5:43pm
geobloke
Yup was looking at it today, Wipac branded.
Post #678479 14th Jan 2018 8:27pm
Mc071963
United Kingdom 2006 Defender 90 Td5 HT Rutland Red
I Had a similar problem and I ended up buying three of these
https://www.ebay.co.uk/itm/12V-Piezo-Elect...2821343796
and then wiring one onto each of the indicator bulb's on the display block in the main Dash
They make a heck of a racket and general force you not to leave the damn indicators on.
volume control is achieved by gaffa taping the two back to back.
no diodes required and they take such little current it has no effect on the flasher rate TD5 90 in Hertfordshire
Post #678534 14th Jan 2018 10:20pm
gilarion
The Bolt on Bits relay is very very quite so much so I can hardly hear it above the engine noise. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #678691 15th Jan 2018 1:54pm
